Wanted
Re: Wanted
Where are you located in Indiana? I'm in Churubusco. The tank grommet (M66005) is still available from your John Deere dealer. Just don't ask for one for a snowmobile. It also fits a 318 Lawn Tractor as well as other small JD lines. Exhaust doughnut???? drawing a blank on that. Anyone working on snowmobiles needs a clutch puller as much as a pair of pliers or screwdrivers. You can purchase a Comet puller from lot's of sources including Dennis Kirk for about $40ish. If you live near me call me at 260-609-2833 and I'll try to help you.
Re: Wanted
I'm west of Plymouth off 30.
I have a puller, just both the clutches were/are stripped. I was thinking of putting a large nut on where the primary unscrews. then puting a gear puller on that. I'll take some pics tonight and post more in the right place.
For the exhaust, I need the gasket that goes between the Y pipe and muffler.
