295/s fuel tanks
295/s fuel tanks
How long is the pickup hose supposed to be on the mid tank? The front tank? How was the front tank hooked up from the factory?
Kurt.
295/s
295/s
Re: 295/s fuel tanks
I usually cut them long enough for the pickup to set on the bottom for both front and rear. I asked about the front tank switch a while ago, and the best solution seemed to be a 2-way switch. I hooked it up so the switch sat just inside the mid-take door.
DLDeere
- Real Name: Howard Olson
Mine is set up with at two-way valve, but that was something someone added many years ago. Originally they were set up one tank connected to the next and the middle tank in line had a sealed gas cap instead of vented. It would suck one tank dry first and then the next.
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
- jdsledsrgr8
- Real Name: Matt Gabler
I got mine 2 tank set system set up correctly, do not ask me how because a mechanic figured it out for me but I will be at Waconia and am happy to have folks tear into it to figure out how this guy did it. I do not think it has a 2 way valve/switch. But I will be the first to say I am not a mechanic just a guy that enjoys JD snowmobiles and the process of finding parts and turning them into new again.
Mt. Horeb WI
1976 Liquidator
1976 Liquidator Clone
1978 Liquifire 440
1976 Liquidator
1978 Liquifire 440
