Has anyone ever fooled around with replacing these gaskets? If so where can they be found or did you just recreate them?
M66565 Liquid Pump gasket
M66717 Engine Inlet Adapter gasket
M66724 Engine Outlet Adapter gasket
Thanks for the insights
Odd Liquidator Gaskets
- jdsledsrgr8
- Real Name: Matt Gabler
Mt. Horeb WI
1976 Liquidator
1976 Liquidator Clone
1978 Liquifire 440
1976 Liquidator
1978 Liquifire 440
Re: Odd Liquidator Gaskets
Cometic Gasket will make them for you..
- 80spitfire
- Real Name: Brian Kottke
I've often wondered about these as well. When I rebuilt mine I just cut out the input and output one with gasket material. The outlet was really easy but the inlet was a little bit of a challenge. I haven't tried the water pump one though. It'd be sweet if someone has some NOS ones of these gaskets that cometic could make copies of.
-Brian
-Brian
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
75' 340/S Rider
77' Liquifire Rider
Brian, they might already have them, Greg Morris I believe sent them gaskets to make a full set for the Dator??? Just call them & ask..
- 80spitfire
Oh really? That'd be even better!
-Brian
-Brian
72' 500 Restored
75' 340/S Rider
77' Liquifire Rider
75' 340/S Rider
77' Liquifire Rider
- jdsledsrgr8
I called them and all they had was base gaskets and exhaust gaskets. It was great to order a base gasket as I needed it.
What I may do is send them my inlet and outlet pieces to have them also have them available.
Mt. Horeb WI
1976 Liquidator
1978 Liquifire 440
1976 Liquidator
1978 Liquifire 440
I'm sure that we had a new Cometic head gasket for Cooters Dator engine last year?? But I slept since then, maybe Chris remembers??
yea i order a fiber and brass head gasket from cometic last year. Thanks
Do you have some drawings of what the gaskets are that you need?
If someone has CAD drawings of the gaskets you need I can cut them on the waterjet.
