does anybody have gaskets (440/5)
- KamJD600
- Real Name: kameron peck
I'm in need of a gasket set for my 440/5 CCW, dennis kirk has a set of Winderosa's that they say work in the catalog but not online. Do they work? Does anybody have a set? also does anybody know what size crank seals i need?
Re: does anybody have gaskets (440/5)
I got a set of winderosa's last year. You gotta watch the seals in them tho. mine came with the early 25mm seal.
You'll need 2 30mm seals.
Kurt.
295/s
295/s
http://newbreedparts.com/index.php?rout ... uct_id=158
This should be the right kit. Kurt is right, they ship the kit with two 25mm ID seals, but I'm fairly certain that the engines needs one 25mm and one 30mm, so I swap one of the seals before sending it.
oh jeeze I for got you have them! I think i got mine from a parts unlimited dealer before I knew.
yeah your right on the seals matt, mine came with 2 25mm seals. Mag side is 25 PTO is 30, and 25 on the really early engines.
Kurt.
295/s
295/s
- KamJD600
thanks guys
- KamJD600
hey Matt what kind of head gaskets come with the kit
I'm not sure what you mean by what kind, so I took a photo.
- KamJD600
ok thats what i need to know thank you
