I had no idea that parting out a sled took so long. My buddy and I started on a 80 LF last weekend....thinking it would be a hour job. Three hours later and some grinding and cutting....it was done.
We had the worst time seperating the tunnel from the front section. There sure are a lot of rivots.
We did however get 13.00 for the Aluminum!! So thats almost enough for a case of cold beverages.
Don't worry guys this sled was shot with no hope of any restoration.
Just thought I would share my Labor Day weekend story.
Eric
Parting a sled out
Parting a sled out
Eric A.
- Danzig
- Real Name: Paul File
Parting a sled out
What goodies do you have after the strip down?
Parting a sled out
Well lets see.
- both ski assemblies (one ski is kinda bent)
- steering linkages
- motor (doesn't turn over)
- decent hood (only one crack in it)
- rear grab bar
- suspension (some bogie wheels are shot)
- secondary and primary clutches (both would need to be cleaned up)
- some wiring
- brakes
- chain and gears
- coil
- tach
Thats about it.... maybe some other small stuff I can't remember
Eric
- steering linkages
- rear grab bar
- some wiring
- brakes
- chain and gears
- coil
- tach
Eric
Eric A.
Stosh
Parting a sled out
And that's exactly why it's called "Labor Day".
I did the same thing last year with a 79 Ski Doo Everest. Told my wife it would take about a couple hours to tear it all down. Two days later, and some Oxy-Acetylene, I finally had the track off from the rusted monster. Nothing ever goes as planned, now a days, I just double my time estimate and add 32 min.
Even then, I'd rather spend a weekend working on a basket case sled than sittin in front of the boob tube. I learn a lot more about vintage iron than I do about watchin info-mercials on how to pump iron and wasting good money doing it.
Parting a sled out
I have parted about a dozen sleds in the last year, and even two of the same model can take quite a bit of a difference in time.
I can also offer a little advice..... Air impact, air ratchets, air cut off, air hammer, torches, and a really big hammer make it go faster.
