SOLD!!! - ENTIRE NOS PARTS INVENTORY FOR SALE
SOLD!!! --- ENTIRE NOS/NEW PARTS INVENTORY ON EBAY.
Link:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... RK:MESE:IT
THIS INVENTORY WILL BE SOLD AS ONE LOT. ALL PARTS ARE INVENTORIED (Quantities current as of Oct 12th), LABELED, SORTED, with SPREADSHEET INCLUDED. THIS IS OVER $13,000 IN INVENTORY AT CURRENT PRICES. MANY PARTS FOR ALL MODELS, INCLUDING 1983-1984 LIQUIFIRE.
REASONABLE OFFERS MAY BE CONSIDERED PRIOR TO END OF AUCTION.
NOS (New) John Deere Snowmobile Parts
<<<<< SCROLL DOWN FOR COMPLETE PARTS LIST >>>>>
I've completed an inventory of my NOS / New John Deere snowmobile parts. This includes hundreds of many very hard-to-find parts for 1983-1984 Liquifires and many parts for the 1980-84 Liquifire, Sportfire, Trailfire, Spitfire, Snowfire, Sprintfire, as well as the 1970's Liquifire, Cyclone, Liquidator, 340s, 295s, JDX's, and 00-series snowmobiles. All parts are NOS / New unless indicated otherwise.
Please email any question and requests, and include your name, email address, and phone number. Payment is via PayPal or cash only. Shipping is available.
Part Number Quantity Description Fitment
AM52039 1 FUEL PICKUP W/ SCREEN ALL MODELS
AM52159 / AM52418 1 EXHAUST CLAMP (SUB AM54218) JDX 00's
AM52195 1 HEADLIGHT SOCKET (1972 400 500) 00's
AM52259 1 KIT, HARDWARE (SCREWS, WASHERS, NUTS)
AM52261 / 100-530 2 WALBRO NEEDLE KIT, HIGH SPEED (WALBRO # 100-530) JDX 00's WALBRO WR & WD CARBS (CHECK FITMENT)
AM52262 / 102-524 2 WALBRO NEEDLE KIT, IDLE (WALBRO # 102-524) JDX 00's WALBRO WDA-31 / WDB-31 / WR-7-5 / WD-8-5 / WD / WRA-31 / WR (CHECK FITMENT)
AM52418 / AM52159 3 EXHAUST CLAMP (REPL AM52159) JDX 00's
AM52449 2 BRACKET W/ GASKET, GAUGES (SPEEDO/TACH) ALL MODELS
AM52473 1 KIT, BATTERY HOLD-DOWN (INCL. HARDWARE) ALL MODELS
AM52515 1 EXHAUST CLAMP JDX 00's
AM52604 / 100-533 2 WALBRO NEEDLE KIT, HIGH SPEED (WALBRO # 100-533) JDX 00's WALBRO CARBS WR-7-5 / WR-8-5 / WRA-31 / WD / WR
AM52847 21 BULB, SPEEDOMETER / TACHOMETER ALL MODELS
AM53093 / 100-534 3 WALBRO CARBURETOR NEEDLE KIT, HIGH SPEED (WALBRO # 100-534 WALBRO CARBURETORS WD-31 / WDA-31 / WDB-31
AM53381 1 TIE ROD END, LH LIQUIFIRE SPORTFIRE TRAILFIRE
AM53413 1 SPACER, REAR IDLER WHEELS LIQUIDATOR LIQUIFIRE CYCLONE 340s
AM53554 1 ANGLE DRIVE, SPEEDOMETER LIQUIFIRE SPORTFIRE TRAILFIRE LIQUIDATOR LIQUIFIRE CYCLONE 340s
AM53733 1 KIT, CLUTCH ROLLER W/ PUCKS LIQUIFIRE CYCLONE 340s JDX 00's
AM53850 1 BRAKE CALIPER ASSEMBLY LIQUIDATOR LIQUIFIRE CYCLONE
AM53887 1 BULB, HALOGEN HEADLIGHT (SOLERO SS181-6260H) H4 ALL FIRE SERIES
AM53907 / AM54220 1 CYLINDERS / ENGINE BLOCK (340 L/C) (KEC 240/23LC) LIQUIFIRE 1976 1977 1978
AM53912 1 ENGINE GASKET KIT (340 L/C) (KEC 240/23LC) LIQUIFIRE 1976 1977 1978
AM54066 1 SKI SHOCK (LIQUIDATOR) LIQUIDATOR
AM54307 1 KIT, 102C CLUTCH 3/4" GUIDE BUTTON / PUCK KIT (6 PCS) LIQUIFIRE SPORTFIRE TRAILFIRE SPRINTFIRE LIQUIDATOR LIQUIFIRE CYCLONE
AM54307 1 KIT, 102C CLUTCH 1/2" GUIDE BUTTON / PUCK KIT (6 PCS) LIQUIFIRE SPORTFIRE TRAILFIRE SPRINTFIRE LIQUIDATOR LIQUIFIRE CYCLONE
AM54371 2 IDLER WHEEL SPITFIRE
AM54384 2 CHAIN TENSIONER KIT SPORTFIRE TRAILFIRE LIQUIFIRE CYCLONE
AM54427 2 NEEDLE, CARB
AM54653 3 CABLE, SPEEDOMETER SPITFIRE
AM54655 1 WIRING HARNESS, SPEEDOMETER SPITFIRE
AM54656 1 SPEEDOMETER KIT SPITFIRE
AM54677 3 HINGE, FUEL TANK DOOR ALL FIRE SERIES LIQUIFIRE 1978 CYCLONE 1978
AM54727 6 BRAKE CALIPER ALL FIRE SERIES
AM54733 1 SPINDLE, SKI / STEERING (SUB AM55251 AND M68976 OR M68977) LIQUIFIRE SPORTFIRE TRAILFIRE
AM54748 1 IDLER WHEEL (6 3/8" OD x 3/4" W x 3/4" ID) CrossRef PPD 6375BR / ARCTIC CAT 104-214 LIQUIFIRE SPORTFIRE TRAILFIRE SNOWFIRE SPRINTFIRE LIQUIFIRE CROSS COUNTRY
AM54770 1 RADIATOR LIQUIFIRE2
AM54784 5 SWITCH, HEADLIGHT DIMMER ALL FIRE SERIES
AM54785 3 BRAKE PAD W/ RETAINER OEM ALL FIRE SERIES
AM54785 4 BRAKE PAD W/ RETAINER AFTERMARKET ALL FIRE SERIES
AM54785 & AM54908 1 KIT, BRAKE PADS AFTERMARKET ALL FIRE SERIES
AM54790 7 SWITCH, BRAKE LIGHT / SAFETY ALL FIRE SERIES
AM54791 / AM55024 1 CABLE, BRAKE (SUB AM55024) LIQUIFIRE SPORTFIRE TRAILFIRE
AM54797 1 HINGE, HOOD SPORTFIRE TRAILFIRE
AM54841 1 FLYWHEEL TRAILFIRE
AM54843 2 IGNITION COIL, PULSING TRAILFIRE
AM54844 2 IGNITION COIL, LIGHTING TRAILFIRE
AM54848 2 BEARING, CRANKSHAFT LIQUIFIRE SPORTFIRE
AM54898 1 CLUTCH, SECONDARY (COMPLETE) SPITFIRE SNOWFIRE
AM54903 1 CABLE, CHOKE (PUSH/PULL) SPITFIRE
AM54908 3 BRAKE PAD / LINING ALL FIRE SERIES
AM54916 7 SPEEDOMETER KIT (INCLU SPEEDO, CABLE, HARDWARE)
AM54964 1 WEAR BAR, CARBIDE (3 BOLT) (2 PCS) 1982 1983 1984 LIQIUFIRE SPORTFIRE SNOWFIRE SPRINTFIRE
AM54984 4 KIT, TORQUE BUTTON (3 PC), SECONDARY CLUTCH LIQUIFIRE 1980 1981 SPORTFIRE ALL
AM54992 1 WIRING HARNESS, MAIN SPITFIRE
AM55004 8 CABLE, THROTTLE SPITFIRE
AM55015 1 TACHOMETER
AM55020 / 04-116-73 2 IDLER WHEEL (5" OD X 3/4" W X 5/8" ID) (Kimpex 04-116-73 or 298877) LIQUIFIRE SPORTFIRE TRAILFIRE
AM55027 9 CAP, RADIATOR / COOLANT LIQUIFIRE 2 SPRINTFIRE
AM55032 3 HEAT SHIELD KIT (HOOD) LIQUIFIRE SPORTFIRE TRAILFIRE
AM55070 2 CAM W/ BUSHING, SECONDARY CLUTCH (M68534) LIQUIFIRE 2
AM55080 / 318531-3010 1 PISTON RINGS, KAWASAKI P/N 3000-121 SPITFIRE
AM55092 2 CAP, SPARK PLUG ALL FIRE SERIES
AM55095 1 COIL LIQUIFIRE SPORTFIRE TRAILFIRE
AM55098 1 ENGINE BASE / PLATE TRAILFIRE
AM55099 8 SPEEDOMETER (W/ DEERE LOGO) ALL FIRE SERIES
AM55102 1 IGNITION COIL, EXCITER TRAILFIRE SPITFIRE SNOWFIRE
AM55103 2 IGNITION COIL, PULSING TRAILFIRE SPITFIRE SNOWFIRE SPRINTFIRE
AM55115 / M68582 4 VENT / GRILLE, HOOD (M68582) LIQUIFIRE SPORTFIRE TRAILFIRE SNOWFIRE
AM55142 1 HANDLEBAR HEATER KIT
AM55147 / AM54657 1 DOOR, FUEL TANK W/ FIREBURST DECAL (NO LATCH) 1980 1981 SPORTFIRE TRAILFIRE SPITFIRE
AM55176 3 CONTACT / REV LIMITER LIQUIFIRE 2
AM55231 12 HITCH PIN AND CABLE KIT ALL MODELS
AM55251 2 SPINDLE, SKI / STEERING (COARSE THREAD)(REPLACES AM54733 M68977) LIQUIFIRE SPORTFIRE TRAILFIRE 1982 1983 1984
AM55301 5 ANGLE DRIVE, SPEEDOMETER LIQUIFIRE SPORTFIRE TRAILFIRE
AM55326 3 TORQUE BUTTON KIT (3 PC), SECONDARY CLUTCH LIQUIFIRE 1982 1983 1984
AM55391 6 TIE ROD END, LH LIQUIFIRE 1982 1983 1984 SPORTFIRE TRAILFIRE
AM55473 1 KIT, TR800 CLUTCH BUSHING (3 PC) LIQUIFIRE 1982 1983 1984
AM55474 1 KIT, TR800 CLUTCH THRUST BEARING & WASHER LIQUIFIRE 1982 1983 1984
AM55476 9 CAM, TR800 CLUTCH (STD) LIQUIFIRE 1982 1983 1984
AM55479 1 KIT, TR800 CLUTCH RAMP (3 PC) LIQUIFIRE 1982 1983 1984
AM55534 1 FUEL RETURN KIT (INCL. ONLY CONNECTOR, 3 TEES, RUBBER BUSHING) LIQUIFIRE 2
AM55563 1 KIT, TR800 CLUTCH WASHERS (partial kit) LIQUIFIRE 1982 1983 1984
AM55598 2 WEAR BAR (3 BOLT) (2 PCS) 1982 1983 1984 LIQIUFIRE SPORTFIRE SNOWFIRE SPRINTFIRE
AM55601 1 KIT, BELT HOLDER ALL FIRE SERIES
AM55680 1 CABLE, THROTTLE SNOWFIRE
AM55694 / AM54782 1 SWITCH, KILL 1983 1984 LIQUIFIRE SNOWFIRE SPRINTFIRE
AM55730 1 REV LIMITER (1984 SPORTFIRE) SPORTFIRE 1984 TRAILFIRE
M63035 2 SUSPENSION SHAFT / PIN (BOGIE SUSPENSION) 295s JDX 00's
M63052 2 INSULATOR, SKI (NYLON) OEM, NOT REPRODUCTION ALL MODELS
M63059 1 HITCH PLATE ALL MODELS
M63125 1 CHAIN (SIZE 35-2 x 92 LINKS) 295s JDX 00's
M63136 1 DRIVESHAFT JDX4, 400, 500
M63161 / M68338 3 BUMPER, HOOD 295s JDX 00's
M63225 3 CHAINCASE PLUG (LARGE RUBBER) 295s JDX 00's
M63228 5 GASKET, GEAR CASE (CORK) ALL FIRE SERIES LIQUIDATOR LIQUIFIRE CYCLONE 340s 295s JDX 00's
M63229 4 GASKET, GEAR CASE (CORK) (SUB FOR M63228) 295s JDX 00's
M63246 1 SPACER, SUSPENSION 1972 400 500
M63271 1 HOSE, BREATHER / OVERFLOW (10 FT) SPORTFIRE TRAILFIRE SPITFIRE SNOWFIRE LIQUIFIRE CYCLONE 340s 295s
M63279 17 PIN, SKI / SPRING (USED AND NEW) ALL MODELS
M63301 5 KEY, IGNITION SPORTFIRE TRAILFIRE LIQUIDATOR LIQUIFIRE CYCLONE 295s JDX 00's
M63378 3 BATTERY HOLD-DOWN BOLT / HOOK ALL MODELS
M63583 1 CCW RECOIL ROPE GUIDE (SUB 65976) 295s JDX 00's
M63610 1 INSULATOR, CARB (WALBRO) 00's WALBRO
M63650 2 SCREW, CARB JDX 00's
M63655 2 SPRING, BRAKE CABLE ALL MODELS
M63673 14 RETAINING WASHER, ACCESS PANEL 295s JDX 00's
M63676 8 WASHER, IDLER WHEELS 295s JDX 00's
M63692 1 CLUTCH BUSHING (BRASS) (I.D. 2.0" x O.D. 2.25" x W 1.125") (0.125" INSIDE BEVELED EDGE)
M63699 17 CLUTCH CAM BUTTON JDX 00's
M63700 2 REFLECTIVE BUMPER TAPE, 3/8" YELLOW (EST. 78 FT PER ROLL) 340s JDX 00's
M63704 2 NUT, INSTRUMENT PANEL SPORTFIRE TRAILFIRE LIQUIDATOR LIQUIFIRE CYCLONE JDX 00's
M63710 37 RIVET, FUEL TANK DOOR ALL FIRE SERIES LIQUIDATOR LIQUIFIRE 1978 CYCLONE 1978
M63721 6 TIE ROD, STEERING 1972 400 500
M63775 30 GROMMET, TAILLIGHT/HEADLIGHT/PANELS ALL MODELS
M63776 1 BRACKET, TAIL LIGHT ALL MODELS
M63786 1 RETAINER, HEADLIGHT LIQUIFIRE SPORTFIRE TRAILFIRE SPITFIRE 340s 295s JDX 00's
M63816 1 LENS, TAIL LIGHT (LLP) ALL MODELS
M63894 10 CLIP, ACCESS PANEL 00's
M63900 2 REFLECTIVE BUMPER TAPE, 3/8" YELLOW (EST. 52 FT PER ROLL) 340s JDX 00's
M63905 4 SCREW, THROTTLE / BRAKE BLOCK SPITFIRE LIQUIDATOR LIQUIFRE CYLCLONE 340s JDX 00's
M63929 1 PLUG, BELLY PAN (MET. GREEN) 295s JDX 00's
M63931 1 DECAL, CAUTION (CONSOLE) 295s JDX 00's
M63979 2 REED VALVE GUIDE LIQUIFIRE CYCLONE JDX 00's
M64132 / M63647 2 WALBRO CHOKE SHAFT (WALBRO # 44-169 / 44-154) JDX 00's WRA-31 / WR-7-5 / WD-8-5 / WDA-31 / WDB-31 / WR / 1612
M64141 6 CORE / BUSHING for SPEEDOMETER / ANGLE DRIVE ALL FIRE SERIES LIQUIDATOR LIQUIFIRE CYCLONE 295s
M64142 6 CORE / KEY, SPEEDOMETER ALL MODELS
M64215 1 DRIVESHAFT 295s JDX 00's
M64480 11 HYFAX, SLIDE RAIL (WHITE) ALL MODELS
M64524 2 REFLECTIVE BUMPER TAPE, 3/8" WHITE (ROLLS)
M64553 5 BOLT, SLIDE RAIL /. SUSPENSION ALL MODELS
M64610 2 SNAP RING, SECONDARY CLUTCH 340s 295s JDX 00's
M64836 / 98-216 5 SPRING, CARB (WALBRO # 98-216)
M64853 1 SPRING, RECOIL LIQUIDATOR LIQUIFIRE CYCLONE 340s 295s JDX 00's
M65306 1 HEADLIGHT BEZEL JDX 00's
M65333 11 MAIN JET / INJECTION NOZZLE (150) LIQUIFIRE SPORTFIRE TRAILFIRE SPITFIRE LIQUIFIRE CYCLONE 295s
M65334 2 MAIN JET / INJECTION NOZZLE (160) LIQUIFIRE SPORTFIRE TRAILFIRE SPITFIRE SNOWFIRE LIQUIFIRE CYCLONE 295s
M65336 1 MAIN JET / INJECTION NOZZLE (120) LIQUIFIRE SPORTFIRE TRAILFIRE SPRINTFIRE SNOWFIRE LIQUIFIRE CYCLONE
M65339 12 WASHER LIQUIFIRE SPORTFIRE LIQUIDATOR LIQUIFIRE CYCLONE 340s 295s
M65342 1 ADJUSTING SCREW ALL FIRE SERIES LIQUIDATOR LIQUIFIRE CYCLONE 340s 295s
M65352 2 C-CLIP, NEEDLE ALL FIRE SERIES LIQUIDATOR LIQUIFIRE CYCLONE 340s 295s
M65353 1 SPRING, SLIDE VALVE LIQUIFIRE SPORTFIRE TRAILFIRE SPRINTFIRE LIQUIDATOR LIQUIFIRE CYCLONE 340s 295s
M65446 2 PLUG, WALBRO CARB JDX 00's
M65449 11 O-RING
M65653 2 GASKET, CYLINDER BASE CYCLONE JDX4 JDX8 400 800
M65666 6 SPRING, REAR SUSPENSION RH LIQUIFIRE CYCLONE JDX
M65667 6 SPRING, REAR SUSPENSION LH LIQUIFIRE CYCLONE JDX
M65697 2 CHAINCASE GASKET 340s
M65871 1 BUSHING, SECONDARY CLUTCH TRAILFIRE SPITFIRE SNOWFIRE SPRINTFIRE LIQUIDATOR LIQUIFIRE CYCLONE
M66005 1 BUSHING / FITTING, FUEL TANK (RUBBER) ALL FIRE SERIES LIQUIDATOR 340s
M66117 1 NUT, CHOKE CABLE ALL FIRE SERIES LIQUIDATOR 340s LIQUIFIRE CYCLONE
M66155 10 SPRING, EXHAUST (2 PC) ALL FIRE SERIES LIQUIFIRE CYCLONE
M66216 5 SPRING, CHAIN TENSIONER LIQUIDATOR LIQUIFIRE CYCLONE
M66303 1 GEAR, 21-TOOTH LIQUIFIRE SPORTFIRE TRAILFIRE LIQUIDATOR LIQUIFIRE CYCLONE
M66338 3 SEAL, AIRBOX / AIR INTAKE (RUBBER) ALL FIRE SERIES LIQUIDATOR LIQUIFIRE CYCLONE
M66343 1 O-RING, CARB DRAIN PLUG SPORTFIRE TRAILFIRE SPITFIRE SNOWFIRE SPRINTFIRE LIQUIDATOR LIQUIFIRE CYCLONE
M66362 4 SHIM, CRANKSHAFT LIQUIFIRE CYCLONE 400
M66364 1 SHIELD, CRANKSHAFT/CRANKCASE LIQUIFIRE CYCLONE 400
M66370 2 RECOIL PULLY LIQUIFIRE CYCLONE 400
M66378 1 SPRING (BLUE), SECONDARY CLUTCH ALL FIRE SERIES LIQUIDATOR LIQUIFIRE CYCLONE
M66381 3 BUSHING, SECONDARY CLUTCH SHEAVE ALL FIRE SERIES LIQUIFIRE 2 (80,81) LIQUIFIRE 1 CYCLONE LIQUIDATOR
M66519 3 SHIM, SECONDARY CLUTCH SHEAVE ALL FIRE SERIES LIQUIDATOR LIQUIFIRE CYCLONE
M66568 11 GASKET/O-RING, TEMP SENDING UNIT LIQUIFIRE 1 LIQUIFIRE 2 LIQUIDATOR SPRINTFIRE
M66580 1 O-RING, WATER PUMP LIQUIFIRE 1976 1977 1978
M66634 6 CLIP, HOOD CABLE ALL FIRE SERIES LIQUIFIRE 1 CYCLONE LIQUIDATOR
M66652 3 PLATE LIQUIFIRE LIQUIDATOR
M66654 1 PLATE, SLIDE VALVE LIQUIFIRE LIQUIDATOR
M66657 3 FLOAT, CARB LIQUIFIRE 2 SPITFIRE LIQUIDATOR
M66661 1 CAP, CARB LIQUIFIRE 2
M66779 2 RETAINER, HOOD DUCT LIQUIFIRE CYCLONE
M66794 4 SPACER BLOCK, IDLER WHEEL (METAL) LIQUIFIRE 1976 1977
M66797 2 FITTING / PLUG, CHAIN CASE LIQUIFIRE SPORTFIRE TRAILFIRE LIQUIFIRE CYCLONE
M66815 2 BUMPER / ISOLATOR, RUBBER (FRAME) LIQUIFIRE CYCLONE
M66889 1 VALVE, SLIDE (3.5)(36mm) LIQUIFIRE CYCLONE
M66894 2 NEEDLE JET / INJECTION NOZZLE (159, P-4) LIQUIFIRE SPORTFIRE SPRINTFIRE LIQUIDATOR LIQUIFIRE CYCLONE
M66928 7 NEEDLE (6DH4) LIQUIFIRE SPORTFIRE SPRINTFIRE LIQUIDATOR LIQUIFIRE CYCLONE
M66977 14 HOSE, UPPER COOLANT LIQUIFIRE 2
M67013 5 TRACK CLIP LIQUIFIRE SPORTFIRE LIQUIFIRE CROSS COUNTRY
M67032 1 SNOWFLAP SPITFIRE SNOWFIRE SPRINTFIRE
M67041 18 BUSHING, SKI SPINDLE SPITFIRE SNOWFIRE SPRINTFIRE
M67057 2 BUSHING, SUSPENSION ARM SPITFIRE
M67072 1 STRAP, LIMITER SPITFIRE
M67159 1 SUSPENSION SPRING, LH LIQUIDATOR LIQUIFIRE CYCLONE
M67762 1 BELT, WATER PUMP / FAN (REPLACES M64188) LIQUIFIRE CYCLONE JDX 00's
M67788 1 BRACKET, ANGLE DRIVE (SPEEDO) SPITFIRE
M67817 1 VALVE TRAILFIRE SPITFIRE SNOWFIRE SPRINTFIRE
M67854 14 BUSHING, IDLER WHEEL LIQUIFIRE SPORTFIRE TRAILFIRE LIQUIFIRE CYCLONE
M67863 1 BASE / BRACKET, SLIDE RAIL LIQUIFIRE SPORTFIRE TRAILFIRE LIQUIFIRE CYCLONE
M67905 2 DECAL, HANDWARMER ALL MODELS
M67948 1 SUSPENSION SPRING, RH LIQUIFIRE SPORTFIRE TRAILFIRE
M67952 1 AXLE, SLIDE RAIL / IDLER WHEEL LIQUIFIRE SPORTFIRE TRAILFIRE
M67969 / AM55256 1 SPROCKET, TRACK DRIVE LIQUIFIRE
M67969 / AM55256 / 04-10817 2 SPROCKET, TRACK DRIVE (KIMPEX 04-10817) LIQUIFIRE
M67992 1 CLAMP, HANDLEBAR LIQUIFIRE SPORTFIRE TRAILFIRE SNOWFIRE SPRINTFIRE
M68001 4 SET SCREW, THROTTLE/BRAKE BLOCK ALL FIRE SERIES
M68020 5 WING NUT, BELT GUARD ALL FIRE SERIES
M68055 4 NUT, CYLINDER HEAD/COVER (TALL NUT) TRAILFIRE
M68059 4 CYLINDER HEAD, 440 TRAILFIRE
M68060 9 GASKET, HEAD (340) TRAILFIRE
M68071 12 CIRCLIP / RETAINER, PISTON PIN ALL FIRE SERIES
M68075 10 WASHER, CRANKSHAFT TRAILFIRE
M68076 1 SHIM, CRANKSHAFT TRAILFIRE SPITFIRE SNOWFIRE
M68085 4 SHIM
M68086 5 GROMMET, SPARK PLUG WIRE (RUBBER) ALL FIRE SERIES
M68092 7 PAWL, RECOIL ALL FIRE SERIES
M68093 3 SPRING, RECOIL ALL FIRE SERIES
M68096 2 SPRING, RECOIL
M68097 7 SPRING, RECOIL ALL FIRE SERIES
M68098 4 REEL, RECOIL ALL FIRE SERIES
M68099 2 SPRING, RECOIL (PRIMARY) ALL FIRE SERIES
M68107 30 GASKET/ WASHER, OIL PUMP / CRANKCASE LIQUIFIRE 2
M68109 8 GASKET/ WASHER, THERMOSTAT COVER / CRANKCASE LIQUIFIRE 2
M68114 4 SEAL, CRANKSHAFT LIQUIFIRE 2
M68117 5 O-RING, CRANKSHAFT LIQUIFIRE 2 SPORTFIRE
M68126 3 O-RING, OIL PUMP / GEAR CASE LIQUIFIRE 2
M68128 5 SHIM, OIL PUMP / GEAR CASE LIQUIFIRE 2
M68129 8 WASHER, OIL PUMP (RUBBER) LIQUIFIRE 2
M68130 6 O-RING, OIL PUMP LIQUIFIRE 2
M68131 9 O-RING, WATER PUMP LIQUIFIRE 2
M68132 25 GASKET, COOLANT PIPE LIQUIFIRE 2
M68133 21 GASKET, COOLANT PIPE LIQUIFIRE 2
M68135 17 GASKET, THERMOSTAT PIPING LIQUIFIRE 2
M68138 36 GASKET, COOLANT PIPE LIQUIFIRE 2
M68142 3 WASHER, RECOIL ALL FIRE SERIES
M68158 2 RECOIL CUP LIQUIFIRE 2
M68164 2 PLATE, RECOIL (NYLON) ALL FIRE SERIES
M68182 2 REFLECTIVE BUMPER TAPE, 1/2" WHITE (ROLLS) LIQUIFIRE SPORTFIRE TRAILFIRE SNOWFIRE SPRINTFIRE
M68209 1 LOCK WASHER, CRANKSHAFT LIQUIFIRE SPORTFIRE TRAILFIRE SPITFIRE SNOWFIRE
M68241 6 GRILL, HEADLIGHT LIQUIFIRE SPORTFIRE TRAILFIRE
M68295 11 O-RING LIQUIFIRE SPORTFIRE SPITFIRE SPRINTFIRE
M68343 16 HOOD ISOLATOR STRIP (RUBBER) (16 FT) ALL FIRE SERIES
M68386 1 CHAIN TIGHTENER / TENSIONER LIQUIFIRE SPORTFIRE TRAILFIRE
M68390 1 BUMPER LIQUIFIRE 2
M68402 3 BUSHING, SECONDARY CLUTCH LIQUIFIRE 1980 1981 SPORTFIRE ALL
M68426 12 GASKET, RUBBER (OIL TANK / GAS TANK) ALL FIRE SERIES
M68429 1 ENGINE BASE / MOUNT SPITFIRE SNOWFIRE
M68449 3 REFLECTIVE BUMPER TAPE, 5/8" WHITE (ROLLS) SPITFIRE
M68477 3 PIN, THROTTLE / BRAKE LEVER ALL FIRE SERIES
M68489 & M68490 1 KIT, BUMPER BOLT (INCL 4-M68489 & 8-M68490) SPORTFIRE TRAILFIRE
M68489 35 BUMPER BOLT SPORTFIRE TRAILFIRE
M68490 6 BUMPER BOLT SPORTFIRE TRAILFIRE SNOWFIRE SPRINTFIRE
M68526 9 RIVET, SNOWFLAP ALL FIRE SERIES
M68557 / M68556 3 PLATE, INSTRUMENT PANEL (REPL M68556) SPORTFIRE TRAILFIRE
M68572 1 SHIM, CRANKSHAFT LIQUIFIRE 2
M68612 3 TERMINAL, SPARK PLUG ALL FIRE SERIES
M68646 6 SPRING, EXHAUST LIQUIFIRE SPORTFIRE
M68654 1 ENGINE BASE / PLATE SPORTFIRE
M68660 3 REFLECTIVE BUMPER TAPE, 1/2" WHITE (ROLLS) LIQUIFIRE SPORTFIRE TRAILFIRE SNOWFIRE SPRINTFIRE
M68666 4 VALVE / HOLDER LIQUIFIRE SPORTFIRE
M68667 1 VALVE, SLIDE (2.5)(36mm) LIQUIFIRE 2
M68688 1 HOOK, HOOD HOLD DOWN LIQUIFIRE 2
M68692 1 POWER JET (115) LIQUIFIRE 2
M68696 2 GASKET, BOWL LIQUIFIRE 2
M68716 / 04-362-01 2 SUSPENSION SPRING, REAR RH (KIMPEX 04-362-01) LIQUIFIRE SPORTFIRE
M68718 3 RUBBER ISOLATOR, EXHAUST PIPE ALL FIRE SERIES
M68724 1 SHAFT, SUSPENSION (MACHINED, THREADED) LIQUIFIRE 2
M68750 2 PLUG, TPR PANEL / BELLY PAN LIQUIFIRE 2
M68754 4 POWER JET (90) LIQUIFIRE SPORTFIRE
M68773 5 POWER JET (105) LIQUIFIRE SPORTFIRE
M68782 6 POWER JET (170) LIQUIFIRE SPORTFIRE
M68793 6 MAIN JET (145) LIQUIFIRE SPORTFIRE SPRINTFIRE
M68809 1 COVER/DECAL, CONSOLE SPORTFIRE TRAILFIRE
M68852 5 GASKET, FUEL GUAGE (AND SPRINTFIRE OIL TANK) LIQUIFIRE 1980 1981 SPRINTFIRE
M68897 5 SCREWS W/ WASHERS (2 PC) SPORTFIRE
M68915 / M68357 8 CAP, OIL TANK (SUB M68357)(ALSO GAS CAP FOR SPITFIRE SNOWFIRE SPRINTFIRE)
M68935 1 HINGE, INSTRUMENT CONSOLE LIQUIFIRE SPORTFIRE TRAILFIRE 1982 1983 1984
M68960 2 ARM, STEERING / SPINDLE (SUB M68976 AND AM55251) FINE THREAD (Note:1 Black, 1 Silver) LIQUIFIRE 2
M68965 1 BRACKET, CONSOLE LIQUIFIRE SPORTFIRE TRAILFIRE
M68977 6 STEERING ARM/SPINDLE, LH (REPL M68961 AM55251) COARSE THREAD LIQUIFIRE 2
M68984 2 SHAFT, IDLER WHEEL 5/8" LIQUIFIRE SPORTFIRE TRAILFIRE (LF 155001-UP, SF 190001-UP)
M68988 3 STEERING ARM/SPINDLE, RH (REPL M68664 AM55251) COARSE THREAD (PAIR W/ M68989) SPORTFIRE TRAILFIRE
M68989 5 STEERING ARM/SPINDLE, LH (REPL M68663 AM55251) COARSE THREAD (PAIR W/ M68988) SPORTFIRE TRAILFIRE
M69040 1 WASHER / RETAINER, GAUGES (3.5 INCH) LIQUIFIRE SPORTFIRE TRAILFIRE SNOWFIRE SPRINTFIRE
M69082 1 BUSHING, SECONDARY CLUTCH LIQUIFIRE 1982 1983 1984
M69170 1 BELT, TR800 LIQUIFIRE 1982 1983 1984
M69209 15 SHAFT, OIL PUMP TRAILFIRE 1982 1983 1984
M69211 3 HUB DRIVE, OIL PUMP SPORTFIRE TRAILFIRE 1982 1983 1984
M69233 2 HOSE (1.25" OD / 1.00" ID) SPORTFIRE TRAILFIRE 1982 1983
M69314 2 SPRING, TR800 PRIMARY CLUTCH, GREEN (STD) LIQUIFIRE 1982 1983 1984
M69404 1 GEAR, 20-TOOTH LIQUIFIRE 2
M69492 / M69543 2 LOCK WASHER, 102C PRIMARY CLUTCH LIQUIFIRE 1980 1981 SPRINTFIRE
TY1098 1 SNOWMOBILE SAFETY FLAG ALL MODELS
10-23 1 SKI (STEFFES) LIQUIFIRE CYCLONE
10-24 2 SKI (REPL AM54678 / AM54192 / AM55281) (STEFFES) LIQUIFIRE SPORTFIRE TRAILFIRE & 1978 LIQUIFIRE CYCLONE
213265 / 213265A 1 COMET CLUTCH BUSHING, MOVABLE FACE (COMET 102C)
216097A 1 COMET CLUTCH PULLER, 102C / 108C / 108-EXP (GENUIN COMET BRAND) (USED) 102C / 108C / 108-EXP CLUTCHES
M81210 6 CLAMP, WIRING ALL FIRE SERIES LIQUIFIRE CYCLONE
N10010 6 CLAMP, WIRING ALL FIRE SERIES LIQUIFIRE CYCLONE LIQUIDATOR 340s 295s JDX 00's
N110223 51 SHIM, CHAINCASE LIQUIFIRE SPORTFIRE TRAILFIRE LIQUIDATOR
xxxxxx 1 SEAT BASE (WOOD W/ T-NUTS) LIQUIFIRE SPORTFIRE TRAILFIRE
07-451 4 FUEL PUMP REPAIR KIT, LLP 07-451 (ROUND) LIQUIFIRE 2
711049 1 GASKET KIT W/ SEALS, WINDEROSA (PARTIAL) LIQUIFIRE 2
xxxxxx 1 KILL SWITCH WITH TETHER & CAP (ARCTIC CAT SPIRIT 3012-225) ALL MODELS
xxxxxx 3 TOOL KIT ALL MODELS
xxxxxx 3 KIT, DRIVE CHAIN AND (2) SPROCKETS (MPM10045) LIQUIFIRE 2
xxxxxx 2 RECOIL REPAIR KIT (PAWLS, SPRINGS, COVER) ALL MODELS
xxxxxx 1 CHOKE REPAIR KIT (LEVER, PIN, SPRING) ALL MODELS
Link:
M65449 11 O-RING
M68085 4 SHIM
Re: NOS (New) John Deere Snowmobile Parts
Hi Randy,
If you don't mind, please send me a copy of your list to joerainville@hotmail.com or give me call this weekend.
Re:NOS (New) John Deere Snowmobile Parts-UPDATED JANUARY 9,
Updated list.
largecar04
- Real Name: scott ohm
Re: NOS (New) John Deere Snowmobile Parts - UPDATED 9/13/2013
That's a whole lot of good stuff! Give me a call and i'll buy some of it for sure. 712-249-4310. thanks
02 arctic cat zr 800 efi
02 arctic cat zr 800 cross country efi
Viktory2k1
Re: NOS (New) John Deere Snowmobile Parts - UPDATED 10/23/2013
Do you have that cover/intake thing that bolts under the hood of a cyclone? like a metal shroud where the intake hose goes, behind the headlight.
Current:
77 John Deere Cyclone 440
98 Yamaha SRX700
Past:
1968 Rupp GT300
1970 Evenrude Bobcat 440
1976 Arctic Cat Cheetah 440
1976 Ski-Doo TN'T Everest 440
1978 Yamaha Exciter 440
1979? Yamaha Enticer 300
1979? Yamaha Enticer 250
1987 Polaris Sprint 340
98 Yamaha SRX700
Past:
1968 Rupp GT300
No I don't believe so.
- Liquifried
I need the two M68261 suspension bushings that you have. Please PM me with price. Shipping is 60030.
Also looking for M67790 & M67157, which are the "pins" used in the front and rear swing arms for Sportfire/Liquifire.
Joe
Joe
Re: NOS (New) John Deere Snowmobile Parts - UPDATED 11/2/2013
Do you still Have the brake lever? M67993 1 LEVER, BRAKE ALL FIRE SERIES
jdjock
- Real Name: Tom Schuster
Randy, I need 2) m68666 holder; 2) m68295 o'rings; 1 m68997 console bumper, if you still have them. Shipped to 57033. Let me know and I will pm you with my address. Thanks, Tom
Farmboy8550
Do you still have the tool kits
Farmboy8550
Looking for am54308 and am54307. Am54934
Farmboy8550
M66245 is that for one or a set? How much?.
M63052
M63052
Re: NOS/New John Deere Snowmobile Parts-UPDATED JANUARY 9, 2014
Inventory list above is UPDATED JANUARY 9, 2014.
Shipping available to the US and CANADA.
Re: NOS/New John Deere Snowmobile Parts-UPDATED JANUARY 29, 2014
Parts list updated 1/29/2014
Hey Randy,
Is everything on there for sale?
