Group,
I am new here and just brought home a cyclone 440 with no compression in the clutch side. Any ideas before I tear it down? Piston or crank seal? Any opinions and where is the best place to get parts for the old girl?
SamV
78 Cyclone no compression on PTO side
Samv,
No compression is caused by one of the following:
leaking head gasket
sticking or broken rings
hole in the piston from a lean condition
broken connecting rod
Pistons,rings and seals are available from http://www.denniskirk.com/jsp/common/Front...TKSM4VMDK0NKIV0
http://www.centralsnowmobile.com/
Remove the head to get a better idea of what is wrong.
leaking head gasket
