trailfire 440 electric start
I ADDED ELECTRIC START TO MY SLED. I MADE UP THE HARNESS FOR THE ELECTRIC START MYSELF AND BOUGHT A REGULATOR FROM DENNIS KIRK #21-53 REG.IT IS A UNIV.FIT WITH 4 WIRES GREEN WITH YELLOW STRIP,YELLOW ,RED ,BLACK THAT LOOKS LIKE JUST A GROUND THATS HOOKS UP TO METAL BODY ON REG.MOUNTING SCREW.DO I NEED A RETIFIER ALSO AND WHERE DO ALL THE WIRES GO, AND I DONT CARE IF THE LIGHTS STILL WORK LIKE THEY DO NOW. I JUST WANT TO CHARGE THE BATTERY,CAN I USE THE RECTIFIER OUT OF A CAR ALTERNATOR??THANKS IN ADVANCE FOR ANY INFORMATION.
I got the same one from image and i couldnt figure it out either, then I found i didnt need it anyway because I had the right rectifier. It has an internal rectifier so you wont need another one. Do you have the rectifier that goes on the battery box?
If not I may be able to help you out. Do you have the oem wiring harness for electric start?
NO I DO NOT HAVE THE REC. ON BATTERY BOX. AND I MADE THE HARNESS FOR THE ELECT.START.
let me see what i can figure out and ill e mail you back this week
ok ive figured out how to make the rectifier for the batt box mount and Ive got one i could ship you for a couple bucks. Ive tested it on my own sled and it works great, I also can give you whatever info you need on the wiring harness,
I asked the local dealer for one, they did a dealer search for them and came up with 3 in the DB, I ordered mine out of Mexico Missouri.
hey rsplash what part nnumber do you remember?
thanx
thanx
Yup, just got it today:
Rectifier P/N: AM54972
I've got the TF parts catalog if you need any other numbers.
thankx, i will check my local jd dealer, even if they cant get one at least i feel good that i can make one easily.
According to my dealer, there were only 3 left in the country, I got one of them.
Last two:
IL: 815-965-0636
PA: 610-588-4088
Last two:
IL: 815-965-0636
PA: 610-588-4088
Ace, have you got this figured out yet?
I've got some spare parts if you need them, solenoids, wire positive terminal to solenoid(1), if anyone needs it. I've got a rectifier but not sure I'm willing to give it up yet.
Sporty- you have any instructions on how to build the rectifier?
Sure, its easy 24 volt zenier diode stud mount.. ebay for about 5 bucks for 2. then a 6 inch lead with a female spade connector. If you want I can get the name of the supplier I got them from on e bay.
The diodes are cheaper than I remembered.
check out ebay item #5796272540.
99cents for 2
99cents for 2
how do you isolate them? The factory ones have some goofy plastic and a transparent film discs.
