I know where there are 6 NOS carbs but they just wont let go
Another try... 80's LF Carbs
Ryker Carruthers
- Real Name: Ryker Carruthers
Anybody have a pair of LF carbs they would be willing to part with? Really would like to ride my sled this winter... I think I have all my clutching sorted but it still has no GO. Tops at 40 and then sowly drops...
When In Doubt, Throttle Out
Re: Another try... 80's LF Carbs
What makes you think it is a carb issue? Are you using the stock air-box? if not, you need to find one. What is the RPM at 40 mph?
- jdrob
- Real Name: Rob
Ryker have you set a jack stand under the rear grab bar while it is running and tried revving it up?? If so what kind of rpms does it run upper end??
Jdrob
Ryker Carruthers
If i have the rear end suspended and rev it it will wrap clear to 8-9000 iirc. When on the ground in snow it lugs and will get up to 30 mph and not very quickly at that. Holdin gthe throttle there it will slowly bog down to where it wants to sputter and die. Wide open the same. Let off and it runs down to idle. All jets are new. Set as manual says to be. Somebody took the power jets out and when i put them back i made my own fiting since the plastic elbow was gone. And i think that may be part of it.
Would really like to find a pair to throw on and see if it is different
Ryker Carruthers
The whole story as it happened. I havent touched it at all this summer so i figured i forgot a few things. Thanks for the help guys.
- jdrob
- Real Name: Rob
Sounds like a clutching issue? Take your belt off. start the sled and leave it sit on the ground and see if it makes a difference. Any chance you had your secondary apart??
Jdrob
- jdrob
- Real Name: Rob
Jdrob
Ryker Carruthers
Rob, i tried that too. Without the belt it had no issue screaming to 9000 and maybe more. I have had the secondary apart. Tried the spring in every hole. Now i'm back to the stock (#2) hole. It has new springs in both clutches. Engages about 4800. Did you by chance watch the videos i had linked in the other thread?
Do you have new O rings in the carb bowls?
Ryker Carruthers
- Danzig
- Real Name: Paul File
Put a new stator in it and a CDI....
You will be running in no time flat !!
Ryker Carruthers
I has a new cdi.. I dont have a stator. I have one in a sport-trailfire that i would be okay with robbing. If it is the same? Reckon it can be pulled and installed without pulling engines?
- Danzig
No and No....new as in used from another machine ?
Ryker Carruthers
It is a new stator in a sportfire motor. I had it all put together but never finished getting it set up in the trailfire. If. The stator from the sporty is the same as LF i can pull it and put it in my LF. Or would it be worth it to find a new stator just for it
- Danzig
Not a fan of this part swapping thing you got going on.....are you putting a sportfire engine into a trailfire but wanna put liquifire carbs on it ??
Get the correct parts, new. Stator and CDI for the correct machine..
I am lost now
I am lost now
