Does anyone have a picture of a 295/s speedo drive and the cable?
My cable was junk and I bought a new one on ebay from dennis kirk. I didn't check the partnumber, but it was listed as 295/s. The end at the drive is huge and won't screw on. Either the cable is wrong or the drive is wrong. I suspect the drive is wrong.
I also feel that the speedo reads low, any idea what the ratio is on the drive?
295/s speedo drive
295/s speedo drive
Kurt.
295/s
295/s
Re: 295/s speedo drive
Well, Neither of them are 10:1.
Turns out I had one from a 72 400 on it, and it's about 1.6:1 ratio.
The correct one is 1.4:1 ratio.
Also the drives for the front motor sleds turn backwards from the mid mounts.
I found the original one to the sled, and was able to save it. It had a cable rusted off in the end.
Kurt.
295/s
295/s
