carb adjustment on 78 liquifire 440
does anybody know how many turns out the larger screw goes on the carbs? I seen the small one is recommended 1 1/4 to 1 1/2 but couldn't find about the other? thanks.
Re: carb adjustment on 78 liquifire 440
The larger screw is for the idle adjustment. Set both carbs the same when adjusting the idle.
