I think I finally got my brain wrapped around what's needed to make the conversion from cleated track to the Yokohama all rubber track. Here's what I have gathered.
Liquifire Parts Used:
* front driver assembly
* suspension
* Yokohama track
Trailfire Parts Used:
* rear arm (This will ensure that everything bolts up to existing bolt holes on the tunnel with no drilling required. Using the Liquifire's rear arm would leave me with 4 holes in the tunnel. Two for the old upper idlers and two for the rear mounts. In addition two new rear mount holes would need to be drilled).
* upper idlers (re-installed in the Trailfire stock location)
* shock
Here are my questions:
* Which set of rear springs do I use? The Trailfire's or the Liquifire's? I am assuming the Trailfires as the Trailfires rear spring locations are further forward than the Liquifire's.
* I will need to add Tunnel wear strips as the track I have found has studs. That wear strip kit is obsolete now. Anyone know what the thickness of the wear strip is supposed to be?
Just trying to figure everthing out before I start. BTW I have found an 80' Liquifire parts sled that I will be getting my parts off of. Is there anything else off the Liquifire I should keep for the Trailfire? Ski's, Ski Shocks etc???
Here is a pic of a Liquifire (Left)and Trailfire (Right) Suspension side by side for reference. This was sent to me by 1982LiquFire440. Thanks Man! Am I missing anything?
Hec
