Reproduced Liquidator Radiator Brackets
We have had reproduced, the Dator Radiator Brackets in two styles. One style is the exact style the Dator used with tabs welded on for the radiator. The other was created because some guys were building clones and didn't want the tabs, just the bracket. That way you can use any radiator you choose. These are high quality and EXACT duplicates of the original. Done in a jig so no corners are kinked. Same ID and OD of the original These are bare metal so that you can paint or powdercoat to your specs. I can have them powdercoated for you if you wish just ask for a quote. If you're building a clone, ask for my pictures showing the location and style of mounting brackets. No need to reinvent the wheel. Because a new jig had to have been built I can't hold the price of the old ones. The original AM 54105 w/tabs sells for $130.00 and without tabs for $120.00. Plus shipping. Thanks for looking. DA/Busco Bullet, Inc.
Re: Reproduced Liquidator Radiator Brackets
Glad to see these done Don. I will have to count mine to see if I need one.
Don, did I have one with tabs ordered??
Grumpy
Grumpy
Not that I can remember Kenny.
