82 Liquifire crankshaft end play
mr-spock
Real Name: Jake
Post by mr-spock »
After the engine has warmed up to operating temp the crankshaft has around an 1/8 inch end play. It seems like the bearings become loose in the crankcase and are floating. Is that normal or should i take it back apart and peen the crankcase so they cant move. I think some other 2 strokes have a pin in there to stop bearings from spinning in the case.
Put er in the ketchup
