80 Liquifire Rear Shock, Coilover?
Has anyone replaced the rear shock in a LF suspension with a coilover style shock for added suspension? Thanks.
Re: 80 Liquifire Rear Shock, Coilover?
Bought one from Image a few years back. Had to shim one end as the bore was larger than the shaft, but otherwise no issues.
Several guys on here have had coil over shocks custom made by Carver Performance.
https://www.carverperformance.com
Busco Bullet stocks the AM55144 standard shock if you want to go that way.
