Cross Country for Sale
cfedorowich
Post by cfedorowich »
1978 Cross Country for Sale. See Registry for Documentation. This machine is 99% correct; the exceptions are the throttle and brake levers and the CDI Module. I purchase it in 2012 and finished restoring it in 2015. It has been on ½ a dozen vintage runs. No rides and no miles put on since 2018. In 2018 the needle/seat on one carb dropped into the bowl resulting in over-fueling. A compression check after showed 120 psi on one cylinder and 90 psi on the other. As a result the motor was disassembled and totally rebuilt. All crank bearings replaced and rod, and rod bearings on the right side replaced; Seals of course replaced. (Done by Associated Crankshaft of Winnipeg). Cylinders ridged honed to .020 over with new pistons and rings. The motor has been run for about 5 minutes since rebuild. Attached are some restore photos plus a current photo. Happy to answer any questions. Not surprising, I have $6000 plus into it. Asking $4000 Canadian. Contact me at cfedorowich@mts.net or text 1-204-365-0879.
cfedorowich
Re: Cross Country for Sale
Sled is Sold.
