spitfire ignition
IH power
Real Name: Daran Harn
spitfire ignition
Post by IH power »
I have 80 spitfire. Apparently ignition systems are hard to come by for these models. Is there another unit that can be swapped into these models? Would a trailfire or invader/intruder cdi/coil work? Would the stator/flywheel need to be changed as well? Just trying to come up with other options for future.
Re: spitfire ignition
I've never tried it but have often wondered if you could convert these to the separate cdi and coil like the 80 trailfire and such use.
