How to remove sticker glue
Deleted User
What is the best way you guys have found to remove the glue from a registration sticker off the cowl without hurting the paint. Thanks Travis
I havent tried it on sleds but Goo-B-Gone has worked w/o damaging other surfaces for me.
- flames4555
I may not work on every type of sticker glue , but i have had great luck using WD-40. Spray it on and let is soak for a few minutes .
good luck
Kevin
good luck
Kevin
Kevin
76 cyclone 440 (dual carbs)
69 Arctic cat panther p22j
1982 kawasaki indtruder
1980 kawasaki 4/6
74 cheetah 440
1967 buick wildcat convertible
1980 kawasaki 4/6
74 cheetah 440
twinkie
Travis,
Use rubbing alcohol, it won't damage the paint. Try to remove it on a day or in the shop when it is fairly warm. A bit of heat from a hair dryer set on a low setting will help too.
Hope this helps!
Greg
Hope this helps!
Greg
1980 Liquifire
1981 Sportfire
1983 Sprintfire
1982 Snowfire
1978 CC Liquifire
1979 340 Trailfire
1982 Trailfire Special
1980 Liquifire
1981 Sportfire
1983 Sprintfire
1982 Snowfire
1978 CC Liquifire
1979 340 Trailfire
Sticker glue can also be removed with plain old peanutbutter. Just bought my wife a helmet and it had a sticker on the shield. put peanutbutter on over night and the next merning it came right off and not a single scratch. :rolleyes:
SamV
SamV
jddecalguy
owning a decal and sign shop for 15 years we have some professional products we've used and tried some worked some don't, things that work are citrus oil (best), wd-40 (second), using gas or alcohal you risk the chance of damaging the finish. spray the sticky area with citrus oil or wd-40 leave sit for 4 to 5 minutes wipe off if it doesn't all come off spray again leave sit for 4 to 5 minutes take a ridgid squeege and lightly scrape acrossed sticky area wipe clean might take 3 or 4 trys.
hope this is helpful,
jddecalguy
jddecalguy
