295/S
How to use the registry:
Year & Serial #
Build Date (if available)
Original/Restored
Owned since
Original Dealer
History/Number if Raced
Special Comments
295/S
295/S Registry
75rat
295/S
Post by 75rat »
Year: 1974 Serial# JDSO 20010M
Build Date: Nov 73
Original/Restored: Restored
Your name: Jim Tradup
Owned since: 2/03
Original Dealer: John Deere Horicon
History/Number if Raced: 89
Special Comments: This was the 10th 295/S built. It was raced by Jim Dano of Nisswa, MN in the 1974 St. Paul-Winnipeg I-500 for John Deere Horicon. Dano was running in 37th place (out of 282 sleds) on the second day when he was hit by a car that wandered on to the race course and put him out of the race. The sled was taken back to Horicon and rebuilt to stock configuration; it was then raced in local races by Dano. It is currently on display at the Snowmobile Hall of Fame in St. Germain, WI. Attached photo shows 295/S in HOF Museum with top 1974 I-500 JD riders Tom Otte (9th) and John Orvis (10th).
295/S
Year & Serial # 1974 -- JDSOC 020882M
Build Date (if available) -- Dec 73
Original/Restored -- Original
Your name (at least first name) Ken Heins
Location (at least state/country) Mo.
Owned since 2003
Original Dealer ??
History/Number if Raced ??
Special Comments. This 295/S has the Bogie/Slider Suspension, All Rubber Track,
Twin Fuel Tanks, & Cross Country Seat
295/S
Year & Serial # -- 1974 -- JDSOC 020756M
Build Date (if available), -- Dec 73
Original/Restored, -- Original
Your name (at least first name) -- Heins Enterprises
Location (at least state/country), -- MN.
Owned since, -- 2006
Original Dealer -- ??
History/Number if Raced, -- ??
Special Comments, -- Has Small Fuel Tank Only, Rubber Track & bogies.
295/S
Year & Serial #, -- 1974, -- JDSOC 020733M
Original/Restored, -- Wrecked/Distroyed
Your name (at least first name), -- Ken Heins
Location (at least state/country) -- MO.
Owned since, -- 2004
Original Dealer, -- ??
Special Comments, -- I was told that Some Previous Owner took this complete 295/S
to a auto wrecking yard for scrape, everyone to lazy to unload
it had the craine opperator drop the magnet on the sled
numorous times until Finally the magnet picked it up,
consequently flattening the tunnel, I was able to salvage the
Cleated Track & Drivers, most of the Suspension, Motor, Carbs,
Electrical, Clutches, Spindles, Aluminum Skis, & Springs
295/S
Year & Serial #: JDSOC 020151M
Build Date (if available): Dec 73
Original/Restored: Original
Your name (at least first name): Matt
Location (at least state/country): Southeast PA
Owned since: 2005
Original Dealer: Windom Farm Service
History/Number if Raced: N/A
kwc
Real Name: Kevin Campbell
295/S
Post by kwc »
Year & Serial: JDSOC 020929M
Build Date: 12/73
Your name: Kevin Campbell
Owned since: 08/2006 - sold 02/2009 to Keith Warning, Joliet, IL
Original Dealer: Wertz Equipment - Charlotte, Michigan
Special Comments: Unfortunately this sled was stored outside for a number of years and was a bit neglected. All the "good parts" (aluminum skis, small tank, air box) were still on the sled, everything was original and the tunnel was very straight.
Kevin Campbell
Vicksburg, Michigan
mgabl072
295/S
Post by mgabl072 »
Year: 1974 Serial# JDSOC 20331M
Build Date: Dec 73
Your name: Matt Gabler
Owned since: 2/07 sold 3/07
Original Dealer: NA
History/Number if Raced: NA
Special Comments: Found in a snowmobile junk yard outside of Madison WI. Scrapped out pretty bad; cracked hood, tunnel, suspension, big aluminum gas tank, slide suspension, track and handle bars was all that was left. Sold to Dave Peterson of WI 3/07.
mgabl072
295/S
Post by mgabl072 »
Year: 1974 Serial# JDSOC 20600M
Build Date: Dec 73
Original/Restored: Original; restoration in process
Owned since: 2/07
Original Dealer: NA
Special Comments: Good shape. Everything orginal except for skis. Small gas tank and air box included. Slide suspension. Restoration in process; picture will be forth coming.
340s
295/S
Post by 340s »
Year: 1974 Serial# JDSOC 020089M
Build Date: Nov 73
Your name: Craig
Owned since: 4/08
Original Dealer: NA
Special Comments: 1000 miles. Everything original. Slide suspension. Great shape.
DLDeere
Real Name: Howard Olson
295/S
Post by DLDeere »
Year 1974 Serial #JDSOC 020426M
Build Date Dec 73
Original/Restored Original
Your name Howard Olson
Location Detroit Lakes, MN
Owned since 10/31/2008
Original Dealer Unknown
History/Number if Raced Unknown
Special Comments
I purchased this from a person in Washington and just received it. It needs some work, but there is hope. It has all of the 295/S standard features, the slide rail cleated track and it also has a storage chest in a luggage rack mounted on the back.
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
GreenFever
295/S
Post by GreenFever »
Year '74 Serial #JDSOC 020489M
Build Date ?
Original/Restored original
Your name Martin Sturm
Location Pigeon,MI
Owned since Jan '09
Original Dealer ?
Special Comments
It has bogie suspension. Not much left but the chassis and the engine.
'72 500 x2
'72 400 not running
'73 400 parts sled
'74 295/S x3 missing many parts
'74 300 not running
'75 600 missing engine parts
'75 800 not running
'73 JDX4 not running
'74 JDX6
'75 JDX8
Cabindweller
Real Name: Jerry Zebro
295/S
Post by Cabindweller »
Year & Serial # JDSOC 020680M
Build Date Dec 1973
Original/Restored Restored
Your name Jerry Zebro
Location Ridgeland, WI
Owned since May 19th 2009
Original Dealer Unknown at this time
History/Number if Raced No race history
Special Comments Now I have a good life long Project.
Last edited by Cabindweller on Sun Oct 23, 2016 11:33 am, edited 3 times in total.
jdsledsrgr8
Real Name: Matt Gabler
Re: 295/S
Post by jdsledsrgr8 »
Now under jdsledsrgr8
mgabl072 wrote:Year: 1974 Serial# JDSOC 20600M
Build Date: Dec 73
Owned since: 2/07
Original Dealer: NA
Mt. Horeb WI
1976 Liquidator
1976 Liquidator Clone
1978 Liquifire 440
guitardude081
Real Name: Jack Durand
Re: 295/S
Post by guitardude081 »
Year & Serial #: JDSOC 020888
Build Date: 10/73
Original/Restored: Original; in pieces awaiting restoration
Your name: Jack
Owned since: Jan '09
Original Dealer: Mies Equipment (Now known as Mies Outland) in Watkins, MN
History: Not known, slide suspension holes have been used, had bogies when I got it. Polaris motor was retrofitted at one time.
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
