can anyone tell me if the shock on the track of my 81 liquifire is supposed to be attached to the slide rails or the idler wheel bracket (mine is attached to the slide rails)
thanx
Adam
track suspension question
Not sure I understand your question (?).....upper end of shock with rubber bushing in shock eye mounts between two mounting ears on the rear arm at the pivot axis.........lower end of shock with no rubber bushing is located between 2 roll pins on a shaft that is bolted between the slide rails for 80/81 models....unless you have a deep snow kit which is different.
Mine is mounted between the slide rails, but it looks like there is anoter mounting point higer on the cross piece for the center set of wheels and I was not sure if the shock was mounted correctly. Thanks for the help
Adam
Adam
