trailfire troubles
redneckchicken
trailfire troubles
hey guys i took the trailfire out tonight for a spin rode it for probably an hour, hour and a half then it lost power and died i got it started again drove it about 500ft and it bogged down and died again this time with no luck of getting it started pulled for about 20 minutes. Has spark and fuel in filter probably half a tank and couldnt see any holes in the piston. any ideas?
trailfire troubles
Id say check the compression first. Then go through the carb see if that is clean. Also pull the fuel line off the carb and pull the cord a few times...see if your pumping fuel.
Good Luck!
Good Luck!
Eric A.
