1980 Trailfire 440
liquifire_freak
1980 Trailfire 440
well everyone i was riding the trailefire today and it was running great then all the sudden my gas line split so i put new gas lines on it and i went back to riding it and it bogged down and died and it started right back up so i checked the lines and they were fine so i figured ill see if it does it again so i rode it and i was going pretty fast then it bogged down again and died and now it wont start theres gas in the lines im getting frustrated with this sled lol but i dont know i might sell them what would they be worth i have the 1980 trailfire that runs just dont know what its lacking and i have the exact same parts sled with no seat and i believe its a trailfire engine or sportfire the sled that runs or will run has what i was told a winter frost 2 paint job its a goldish color but i really want to get this fixed or im just gunna sell it but i would prefer fixing it hope you guys can help!!!!!!!!!!!!
Tyler
Tyler
liquifire_freak
1980 Trailfire 440
im gunna throw some new plugs in it today dont think it'll do much just hoping you guys can give me some ideas of whats a matter
Tyler
Tyler
1980 Trailfire 440
If you fuel lines split from old age maybe your pulse line has split also.
This would cause the fuel pump to operate intermitantly.
Most noteable at high rpms.
liquifire_freak
1980 Trailfire 440
the pulse line is new too im just out of ideas it aeems like when i get it running it breaks hopefully we can get this problem out too and hopefully it'll be all the bugs out of its system
1980 Trailfire 440
buy the way if you want to update wut sleds you have, click on ur name when your logged in, top left hand corner, then in the middle of that page click edit my signature
on the sleds, sounds like a fuel problem, or air is getting in something
1980 Trailfire 440
Couple things to check 1 would be squirt gas in the carb or spark plug holes and see if it fires just to have gas in the lines does not mean its getting into the carb it does not take much crude to stick the inlet needle on these carbs. If the needle sticks closed the gas will fill the line right to the carb but not the bowl of the carb. If it wont fire on the squirted in gas do a compresion check you may have burned a piston from a lean condition specially if it happened going fast.
1980 Trailfire 440
I am thinking Andy may be right.
Pull the plugs and look in the hole with a flashlight.
If you see a hole in the piston....... bad news.
Also look for white specks on the spark plug electrodes.
If all looks good , test compression.
liquifire_freak
1980 Trailfire 440
there were no white specs on the plugs they looked pretty good actually but ill try firing it with gas in the carb or plugs holes tomorrow ill let you guys know how it is goes thanks everyone and im always willing for ideas i really actually am starting to learn quiet a bit of info about john deeres i just get frustrated easily when i work on it all the time and hardly get to ride it lol well talk at you guys later
Tyler
Tyler
1980 Trailfire 440
maybe you have water in your fuel.
liquifire_freak
1980 Trailfire 440
my sled quit about 5 nites ago as everyone knows i started trying to get it runing last nite and it wont hardly pull over like its locked up but for the last 5 days ive tried to start it like 3 times a day pulling it abot 15 times a day and it pulled over fine now it wont we've got 12-15 inches i want to ride it so any help will be gratefully appreciated thanks
Tyler
Tyler
Liquifire 4/6
1980 Trailfire 440
Just a shot in the dark here. You say your gas lines split? Sounds like they musta been pretty rotten. Perhaps some of the plastic particles from inside the gas line made it into the carb and are now lodged in your needle valve causing the carb to pass fuel into the crankcase which would in turn, cause your engine to hydralock which would make it difficult or even impossible to crank over. Hope that's all it is and that you don't have serious internal engine damage.
Peter from Roblin, Manitoba
liquifire_freak
1980 Trailfire 440
well good new for now lol i un thawed it in a warm shop and took the carb off again and figured out the needle valve wasnt shutting all the way again so i bent it down even more now and it started after about 15 20 pulls didnt ride it that much because the air box wasnt on by the way what is the easiest way to put the airbox and crb boot back on i always have a heck of a time getting it on well thanks everyone for the help and ill come back if something else happens lol
Tyler
Tyler
