81 Liquifire runs?
Eaglei
81 Liquifire runs?
Post by Eaglei »
Hello Everyone,
I started my 81 Liquifire, after going thru the carbs and the usual pre-season check.
It starts good, idles right where its supposed to, but the moment I touch the throttle it starts to die slowly losing RPM's then quiting. It will start right up and do the same thing all over. I could use a littlle Tech help! Thanks, Mike
MARK
81 Liquifire runs?
Post by MARK »
Mike, as it starts to bog out try flipping the choke lever at the same time you push the throttle if it helps then try cleaning your carbs again did you take the pilot jets out of the carb OR just blow through them???? Mark
