83 Liquifire Driveshaft
deerecrazy82
Post by deerecrazy82 »
When I assemble the driveshaft on my sled it has alot of side to side slop allowing the shaft to actually be pulled right out. Seems as though i am missing something. Are there suppose to be locking collars on the shaft to prevent this or what? I am putting a bearing flange on then the bearing and putting it throught the tunnel and putting the other flange on the other side. Is this the correct procedure?
Both bearings should be on the inside of the tunnel, Hey Harley have you got a schematic that you can post for him to see
Ken
deerecrazy82,
This is a link to Ryan's online service manual.
http://www.ryanquick.com/jd/info/pictures/134.html
Any side to side movement should be eliminated once the lower sprocket is tightened in the chaincase.
