Will cylinders off a 1980 Kawasaki Intruder 440, fit on a 1979 Trailfire 440 ?
or would a direct engine swap work ?
In catalogs I see the piston number is the same .
Thanks for the info ,Invader440 wrote:Intruder cylinders won't work but you could use Drifter cylinders. Pistons are the same. Intuder is based on the T7 block so the mounting bolt pattern is different.
