Liquifire CDI box?
Liquifire CDI box?
Did a 1980 440 LF use a different CDI box than a 1981 LF? I have a 1981 LF with a bad CDI box, it seems like I will have to pull the motor to get it off, it is held on with big phillips screws and no room to get at them. I have a 1980 440 LF parts sled and a 1983 440 LF parts sled will either of those CDI boxes work on the 1981?
Liquifire CDI box?
Id bet they are aslong as they have the same amount of wires and plugs. I used a trailfire cdi on a invader motor which is very similar to the lf and yes that bottom screw was a bear think I had to remove the radiator and carbs.
