I just replace the fuel lines, and filter in the Sprintfire, and now it won't suck any gas. I blow in the tank w/ the lines disconected, and the fuel pump starts shooting fuel, so I know that the pump is good. When the motor runs w/ gas in the cylinders, the carb won't suck any gas. Is it time for a rebuild, or is there another easy problem. This sled has already run this year, and it ran great, but the fuel lines cracked so I replaced them. Any thoughts.
~Jack
Sprintfire carb help
- guitardude081
- Real Name: Jack Durand
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
1983 Trailfire LX
(3)1974 295/S
1975 340/S
Did you check the one in the tank??if that one falls off you wont get any fuel unless it's a 1/4 tank or more
jddecalguy
make sure you have all the lines in the right place. did you replace the impluse line it could have cracked when you were replacing the other lines.
jddecalguy
jddecalguy
do like jddecalguy said another thing is sometimes when you replace an impulse line if its to long it can kink specialy with lower qaulity line.
- guitardude081
It's not kinked, It revs, It just seems like a belt is slipping or something. I'm either going to sell it, or put it in storage because I'm trying to buy my 98 indy back, if the guy will bring the price down to blue book. He wants $3000 for a $1200 sled, and that's high book too.
~Jack
~Jack
1983 Trailfire LX
(3)1974 295/S
1975 340/S
1983 Trailfire LX
(3)1974 295/S
1975 340/S
