track interchange info
krazinite2003
Post by krazinite2003 »
hi guys i am confused i was reading the track interchange info and it says that all direct drive sleds spitfire ,snow and sprintfire will interchange as well as the 79-80 trailfire and 80 sportfire how can the trailfire track fit if ti is 15 3/4 in can some one shed some light on this for me please
i need to find a track for my spitfire this is why im asking
Since I wrote the original FAQ, I can shed some light on this. Deere did not make the Trailfire cleated track wider until 1982 and used the wider version through 1984. The Sportfire only used this wider track one year, in 1981, as it got the Liquifire rubber track in 1982.
The 1979 Trailfire used the exact same track as the 78-79 Spitfire. When the chevron lug pattern was added to the cleated track in 1980, the Spit, Trail and Sport all used it. This was the same track used on all the 80-84 Direct Drive sleds, the Spit, Sprint and Snowfire.
Therefore, an Spit, Sprint, Snow or 79-80 Trail or 80 Sportfire track will fit your sleds.
I hope this answers your questions.
-Joe Rainville
krazinite2003
i just looked at the add looks good but i thought the spit had a 116x15 and the add says 121 and yes i now have a better understanding of the track interchange so i can go ahead and buy the 79 trailfire right i may have parts for sale in the future
Kranz,
I am pretty sure the 121" it a typo, as it looks like a Spitfire track to me. Deere patented that Chevron lug that was taller than the cleat. You in fact are looking for a 121X15" track, with a 2" drive lug pitch.
Good Luck!
-Rainville
krazinite2003
im just going on the info in the model section it appears to be incorect but if i am understanding i can but a 79 trailfire the track WILL fit the spitfire right i can also buy a 82 trailfire oh hang on you are saying it wont only the 79-80 will fit but the model section says the 80 trialfire uses the 15in track hhhmmmmm maybe some one should fix the model section just my opinon
Kranz,
It may have been known to others like Rich, but it only came to light a few years ago that Deere widened the "15" cleated tracks on the chaincase sleds (Trail and Sportfire) in 1981. I think the Model section was done years before by Lesniak who merged sites with Matt over 10 years ago.
As I said, any track from any year Spitfire (78-82) Sprint and Snowfire (82-84) or early Trailfire (79-80) and the 1980 Sportfire will interchange with each other and fit your Spitfire. It's only the orginal 81-84 Trailfire and 81 Sportfires tracks are two wide to fit the Direct Drive sleds tunnel.
-Rainville
mikehjd
Post by mikehjd »
If you go to www.muscle-iron.com and then to their JD snowmobile page link near the bottom on the left-hand side on the main page. They put the track out of a 79 trailfire on an 80 spitfire. They are located in Saskatoon. It is an interesting site as you can see different modifications they have done to JD snowmobiles.
