Are the stators the same? Are the stators on Kawasaki engines swappable between the liquifire, trailfire, sportfire, sprintfire?
I am guessing you can??? If the connections are the same they should work.....
If you cant....what are the differences?
Stator Question
Stator Question
Eric A.
Stator Question
ask the guys oon kawasakitrax.com Bunch of good knowledgable guys there.
Stator Question
Rich...
Do you know if the stators are the same between those sled models?
Eric A.
Stator Question
if you look up the part #'s in the parts manuals i believe that the sportfire and liquifires with serial #s <del>over </del> UNDER 190000 are the same part numbers. i whould imagine that all the stators whould be kinda interchangeable- whould probably be close enough to get it to run, but run the part #s first and get coils that match.
Stator Question
Thanks for the info guys!
Rich,
We all know you are one of the many "good knowledgable guys" on this site!!
Rich,
Eric A.
Stator Question
take it to the limit is correct- i read the book wrong, the stators for the sportfire and liquifire UNDER 190000 are the same
according to PC-1743 (02-NOV-83) sportfire the stator is AM55097 and in PC-1742 (04-JAN-84) liquifire the stator for liquifires below 190000 is AM55097 but over 190001 the stator is AM55530.
