jd 800 44reed cdi
jd 800 44reed cdi
looking for a little help with th 800 ne carb fuel ,lines,coils cdi, 125 psi 128 psi on cylnders great spark,fule is moving through the lines but will not start. will a bad reed valve cuase this. tha c rank seals are new also thanks
jd400 1973 running
jd800 1975 running
liquifier 440 1977 runn
sprintfire 340 1983 running
nitro 440 1973 rupp ????????
77 cyclone 440 basket case
working on resto 75 x8
jd800 1975 running
Re: jd 800 44reed cdi
Check your exhaust, it may be blocked up with a mouse nest.
sorry harley how do you get into chat room
jd400 1973 running
jd800 1975 running
jd800 1975 running
Go back to the home page and click on the link for the chat room
