brake band repair
mike817o
brake band repair
Post by mike817o »
has anybody ever repaired these by reattaching the pad (shoe) to the metal band? Is there any glue or adhesive that seems to work? Cause i found new ones for 53 dollars a piece and i was wondering if there is a salvage these before paying to replace them. Any help would be appreciated. Thanks Mike and Darian.
'72- 400 x2, 500
'74- JDX4 Specialx2, JDX6x3
'75- 300x2, 400, 800x2 JDX8
Re: brake band repair
Mike, I found some NOS ones a while back & the glue had come loose on all of them, Or did once I flexed them. I found a local brake re-builder here in Kansas City that said he could re-bond them so I have about 6 that I had redone with new linings. The Old part number for these does sub to a newer number which Deere still sells but they are a little different..
JD600
Post by JD600 »
Kenny,
Even though the new ones are different, will they still fit and function properly?
DE
Dustin Elder
Salem, OH
DE, that I don't know I was just told by my dealer that the new number number is still available, someone else told me that they were a little different.
I'll sell the ones that I had rebuilt for $50.00 each with $7.50 shipping.
Basically everything is brand new with using today's adhesive technology & NOS steel outer's
RAT540
Real Name: DAVE
Post by RAT540 »
I WENT TROUGHT THIS LAST YR,DEERE STILL SELLS THEM AN I BOUGHT ONE LOOKS THE SAME,THATS IT . THE METAL SRAP IS TO THICK TO USE FOR THE FINGER PADDLE, I RETURNED IT,TOOK MY LOCAL PARTS STORE AND RELINE TRUCK BRAKES THERE. HE COULDNT DO ,HE SENT IT OUT TO A PLACE THAT DOES RELINE THAT STYLE THERES A SPECCAL PROCESS IN DOING IT YOU GLUE IT WITH A SPECIAL GLUE THEN ITS BAKED
IF ANYBODY NEEDS IT ILL FIND A NUMBER OR ADDRESS AND NAME OF THIS CO.
I THINK IT IN OHIO DAVE
75 800 440
79 TRAILFIRE 440
79 KAWI INVADER 440
06 SKI-DOO MACH Z 1000CC
AMG
Post by AMG »
A friend of mine in Duluth has a shop that builds special brake pads and linings.
He also builds the special clutches for the Dodge Viper Race team too!!
He made special pads for my hopped up 85 F350 Turbo Diesel. He re-arced the pad(s) for better surface contact with the rear drum etc..... If your interested... I can pass his number along....... :usa:
James B.
Duluth, MN
