1988 jag brake rotor help
my buddy brought me a jag to work on the brake rotor is loose and ratting how do i tighting it up 4 him
Re: 1988 jag brake rotor help
Some sleds ( including the Deere's ) use a spring type clip that mounts on top of the 1/2 moon key, this clip then keeps the rotor snug on the shaft, & still allows it to have some sideways movement as the brake is applied .. If the sled has been run for many miles with a loose rotor there might be excessive wear to the Key, shaft, or rotor key way, it really should be disassembled & inspected to see if any of these are the problem..
Ken
Ken
As Kenny started some movement is necessary for proper braking but a lot of sleds with negleted maintenance have issues with the hub and shaft. If you dont fix it it will get worst and the jack shaft can break.
do i have 2 tear the chaincase apart 2 get the shaft out and hows the clutch side apart
Yep, take it all apart. Look for worn shaft bearings, worn chain and sprockets, clutch issues, ect.
There is seldom only one thing that need attention.
What year Jag?
What year Jag?
its 1988 440cc
