First. Why are there o-rings around all the bearings ? What purpose do they serve ? Pretty much all of the ones on the one out of our spitfire are pretty hard, and some are split. Considering there is a groove at the crankcase centerline, I can't see how they seal anything. Do they need to be soft and one piece ? Can I use some case sealer to fill in the split part ?
Second. The center seal on this one feels a lot looser than I expected. I did have this thing running before I tore it apart and it did seem to idle ok. I imagine if it were bad, I would need a new crank. Do these seal under crankcase pressure ? Please tell me they do
I read through the service manual and it doesn't seem to talk about this. Check end play and make sure the center seal is lined up is about all I see.
Finally, I assume it is safe to wipe some case sealer all the way around the outside of the center seal ?
Thanks in advance for all the help.
Kevin
