80 LF carbs problem
bruham
80 LF carbs problem
Post by bruham »
My 80LF was running great until I took it to a guy to put on a new throttle cable/fuel lines...now it starts up like normal and sounds/runs great idleing until you give it gas then it falls over itself like running on one cylinder but both are firing fine....could this be a jet plugged..any help would nice
webman
Re: 80 LF carbs problem
Post by webman »
Check the choke. Had the same thing with mine. I adjusted the choke with the dash up, and it would run great. Put it down and it idled fine, but had no power.
bruham
Post by bruham »
problem fixed carb was dirty..again
