liquifire carbs on a 340/s
hello ,im getting down to the short hairs on my 340/s [about finished with it} the carbs i got with it i think arent the originals ,i have a set that came off of a running 340 liquifire '76 should they be the correct carb ? should they be close on jetting ? any reason to not use them ? wade
Re: liquifire carbs on a 340/s
340/S Std carb 34-68
Jetting
Mains, factory installed LH carb 260, RH carb 250, + 0 to + 40 deg
Pilots = # 40
Jet, Needle 6DH3-3
Needle, Jet P-0
Throttle valve, 2.5
Air Jet, 0.7
Jetting
Pilots = # 40
Jet, Needle 6DH3-3
Needle, Jet P-0
Throttle valve, 2.5
Air Jet, 0.7
kenny you are the bomb thanks for the info , wade
Wade, I've been called a lot of things in my life but never a bomb, although I do have a 750 pounder setting in my basement..
thats awesome!! thanks again for the help wade
- HoosierDeereMan
- Real Name: Troy Miley
Wade,
I ran the that exact same set up last year at the HOF ride and was very rich! We raised the "E" clips on the needle jets to the top groove to lean it out. It helped but didn't cure my too rich condition. I plan on dropping one main jet size to 250 PTO and 240 Mag.
Hope this helps.
Troy
Hope this helps.
Troy
thanks guys that will get me a great starting point wade
I have #30 pilots in mine, and may drop down to #25.
Be prepared to watch the fuel level drop as you ride! These things suck gas at an unbelievable rate!
probably be too busy crappin myself worrying about my glass pan to worry about gas !!!!!!!!!!
another words ill be walking back to house often i bet
thanks wade
hello so i took my 340/s carbs (76 liquifire 340) tonite and the have 45 pilots 180 mains 6dh3 needles with e clip in bottom groove , it would seem this thing may be fat on the bottom end and lean upstairs comparing these carbs to what others have run and kennys info about how they were originally equipped ,comments ?? wade
DLDeere
- Real Name: Howard Olson
I can't answer your questions, but here's a link to a great Mikuni manual that may help you.
http://www.bayshorecad.com/Sleds/Litera ... manual.pdf
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
- HoosierDeereMan
Wade,
Keep in mind that those carbs came off a reed valve engine. The 340/S is piston ported so the jetting will be different.
Troy
Troy
