78 Liquifire piston ? for HarleySportser
He Harley a few months ago we talked about piston for my 78 cold you give me part numbers for Dk pto side piston,rings, and needle bearing again Ive lost it. I know you said the needle bearing was a different number then what they called for. Thanks Shannon
Shannon,
The DK part number for standard bore,pto side:
13-585(complete piston assembly/with rings and pin,clips)
14-310 needle bearing(18x22x22) kec /22 engine
if for a liquifire, order needle bearing below.
13-313 needle bearing(18x23x22)
13-586R ring set
Harley
13-586R ring set
Harley
Thanks Harley got your email ordering tonight. Shannon
