clutch alingment
motorhead255
clutch alingment
Post by motorhead255 »
i'm wondering how to properly aling the clutches on my 78 liquifire
78 Liquifire 440
81 440 invader ( very fast )
Re: clutch alingment
Check out the online service manual.
http://www.vintagesnow.com/John_Deere_f ... yclone.pdf
motorhead255
is there a way to do it with out using the john deere alingment tool since i sure they are hard to come by, or does someone have one to measure i can just make one (i work at a machine shop)
78 Liquifire 440
78440liquid
Post by 78440liquid »
Check your local Deere dealer-they may still have the tool hanging on a wall somewhere. I bought a couple of alignment tools from Rich (takeittothelimit) and then found out later that we had those tools in our toolroom! (I work at a JD dealer)
motorhead255,
Here are a few ways to try and get the clutches close enough without the proper tools.
-Remove engine from pan and turn it over and look at the baseplate mounts to see if the mounting bolts have been moved from the original place which would have left wear marks on the base plate. Return to orignal marks
-Use a 20 inch long, 3/8 square key stock, laying it inside both primary and secondary clutchs. Measure the distance from the engine side of the primary to inside edge of the key stock,. Add / substract shims behind secondary to achive 1 1/4 front measurement. Measure both front side and rear side of primary, move engine to have both measurements equal. See page 26 of
http://www.vintagesnow.com/John_Deere_f ... manual.pdf
-The center to center distance between the clutches is approx 292 mm.
motorhead255
thanks for the info! it looks like i got it back in alingment! woohoo no more shreaded belts!!
78 Liquifire 440
