1980 Sportfire Rear Shock Replacement
jdsledder
Post by jdsledder »
I need to replace the rear shock on my 80 sportfire. I used the "Search" feature on this forum and found several options. The best fitting shock I found was the Kimpex 08-114-16 from DK, but this shock is for a front ski not the rear suspension. Do you think the front ski shock will be properly damped for the rear suspension? I think it may not be stiff enough to handle the rear suspension loads. There are some other Kimpex shocks like a 08-114-14 which is a rear shock but the extended length is a little too short 11 3/4" vs 12" extended, also the eyelets are 5/8 " instead of 7/16" stock. I would have to make bushings for this shock. Do you think anybody would have the JD shock OEM #AM54745. I would also consider a coil over shock if one was available and not to pricey. I would appreciate any advice on the rear shock replacement for the 80 SF.
