decal removal
decal removal
Need some advice:
I need to clean up a '72 hood of the decals and stripe. The registration stickers and numbers peeled off fine, but the Deere applied decals are tenacious. I'm using heat, but I can't get them top peel, I get little slivers, and it appears I'm doing an unacceptable amount of damage to the paint underneath.
Any good ideas?
80spitfire
Real Name: Brian Kottke
Re: decal removal
Post by 80spitfire »
I've used eraser wheels with pretty good luck. Never been to concerned with the paint though since I planned on repainting anyways. It definitely works really good though and it won't gouge the paint up, but it may dull it a bit.
-Brian
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
Re: decal removal
Sean "Mottsi" used the eraser wheel on his hood with good results but I'm never used one.
Re: decal removal
Chris uses the eraser all the time & when he's done it seems to be a good job & the paint isn't hurt unless you burn it, & it seems that you'd really have to be pushing to do that.
Grumpy
SpitfireKing
Re: decal removal
Post by SpitfireKing »
Liquifire4/6 posted that Off Deep woods worked fantastic for decal removal, might be worth a shot
Re: decal removal
SpitfireKing wrote:Liquifire4/6 posted that Off Deep woods worked fantastic for decal removal, might be worth a shot
AND........he hasn't had a mosquito in the shop for three years!!!!
Re: decal removal
Tried the DW OFF, does work to a degree. Softens the adhesive agent under the decal, but it also softens the paint.
Got about half the leaping deer off one side, but the remainder stubbornly remains.
I'm going to get one of the eraser wheels and try that.
Jimmy
Real Name: James Lalk
Re: decal removal
Post by Jimmy »
My question is "What is an eraser wheel"???? And where do you get one??
James Lalk
Sumner,Ia
Invader440
Re: decal removal
Post by Invader440 »
Jimmy wrote:My question is "What is an eraser wheel"???? And where do you get one??
http://www.youtube.com/watch?v=HHKN5_UfDik
Check your auto parts store.
Re: decal removal
The user of the drill in the video is having a problem keeping the wheel in contact with the surface.
Bent arbor? Wheel not centered in the arbor?
I have used an eraser wheel for years and they work great.
Even on those pesky vintage MN License decals which used some kind of adhesive that stuck so well it was outlawed years ago.
Look for the wheels that look like a gum eraser in color and are very soft.
They work best.
Also a side to side motion is the trick, not allowing the wheel to contact full decal.
Keeping the wheel flat on the surface will make it last longer too.
Danzig
Real Name: Paul File
Re: decal removal
Post by Danzig »
Re: decal removal
So the eraser wheel arrived ( bought a 3M wheel off Amazon ), so I eagerly approached the hood to try it out.
The result was...nada, zip, nothing! It did not touch that 40 year old decal. :wall:
Out of desperation, I tried scraping it off with my jack knife again, and to my surprise I started peeling it off in narrow strips. This is the decal I had sprayed the OFF on, and it must have affected it, because a decal that had not gotten the OFF treatment wouldn't do this. The adhesive remained, but the reflective layer peeled off.
So now I try the wheel on the adhesive, but saw limited success. So I sprayed the area with OFF and tried the wheel again, and it worked much better. However, don't do this on paint you don't want to mess up.
S_Kyle
Real Name: Scott Kyle
Re: decal removal
Post by S_Kyle »
wow, that is some kind of stubborn. Sound like the bulkhead out of Adams cyclone soda, chemical stripper nothing. That paint would not come off, every once in a while you find things like that.
JDMIKE8100
Re: decal removal
Post by JDMIKE8100 »
Put new hood decals on my 76 Liquifire a couple of years back.
I unwittingly put the hood on a table outside in the sun on a 85-90 degree day in the summer came back
a couple of hours later and the decals came off in one piece.
Used a tiny bit of automotive paint thinner to remove any residue that remained.
The S Man
Real Name: Ron Sonnek
Re: decal removal
Post by The S Man »
After you heat and get the decal off and you have the stick-um left on 3m makes a remover that works great. I am at work now so I cant give you the exact number. But it is used to take the woodgrain decals off them darn mini vans. I have used this stuff for years, spray it on let it sit a few minutes then I use a plastic bondo spreader to scrap off the stick-um...
