75 JDX8 Tach
kdowning08
75 JDX8 Tach
Post by kdowning08 »
The tach on my 75 JDX8 doesnt work correctly. When the sled idles the tach seems to work correctly. But when if I give it any throttle the tach goes to zero and stays their. I cleaned all wire connections but nothing seemed to help. Thanks in advanced.
Keith
Re: 75 JDX8 Tach
Try reversing the red and yellow wires.
JD600
Re: 75 JDX8 Tach
Post by JD600 »
Does your X8 have a CDI ignition or a points ignition? If it its a 75, it could have either one. These 2 ignitions require different tachs because of the number of pulse coils in the stator.
DE
Re: 75 JDX8 Tach
Good point Justin.
So the question for Keith is did you replace the tach?
kdowning08
Re: 75 JDX8 Tach
Its a CDI not points. I never replaced it that I recall. Is there any way to tell the difference between teh two? I first have to put the engine back together before can do any real testing.
JD600
Re: 75 JDX8 Tach
Post by JD600 »
Does one of the wires have an in line glass fuse? The next question would be, do your lights work?
DE
kdowning08
Re: 75 JDX8 Tach
Yea it has a fuse and the fuse isnt blown, I tested it with a volt meter. The headlight works also. I also need a cylinder for it on the stator side. I cant find both .040 over pistons for it. PM me if anyone has one. (I also put my wanted cylinder in the classified section.)
JD600
Re: 75 JDX8 Tach
Post by JD600 »
Kieth,
I'm about 90% certain that these pistons are still avalible aftermarket. Matt, can you get them from PU or SPI?
DE
Re: 75 JDX8 Tach
kdowning08 wrote:Yea it has a fuse and the fuse isnt blown, I tested it with a volt meter. The headlight works also. I also need a cylinder for it on the stator side. I cant find both .040 over pistons for it. PM me if anyone has one. (I also put my wanted cylinder in the classified section.)
Dennis Kirk Part #: 13-589, left hand... 13-890, right hand
Re: 75 JDX8 Tach
Sorry, I can't be of any help. It's most likely been discontinued for a while.
Re: 75 JDX8 Tach
Dennis Kirk Part #: 13-589, left hand... 13-590, right hand
These part #'s were from a 2009 DK catalog. The right hand piston is now obsolete. The left hand is still available.
