75 JDX8 Tach
75 JDX8 Tach
The tach on my 75 JDX8 doesnt work correctly. When the sled idles the tach seems to work correctly. But when if I give it any throttle the tach goes to zero and stays their. I cleaned all wire connections but nothing seemed to help. Thanks in advanced.
Keith
Keith
Re: 75 JDX8 Tach
Does your X8 have a CDI ignition or a points ignition? If it its a 75, it could have either one. These 2 ignitions require different tachs because of the number of pulse coils in the stator.
DE
DE
Dustin Elder
Salem, OH
Salem, OH
Re: 75 JDX8 Tach
Good point Justin.
So the question for Keith is did you replace the tach?
Re: 75 JDX8 Tach
Its a CDI not points. I never replaced it that I recall. Is there any way to tell the difference between teh two? I first have to put the engine back together before can do any real testing.
Re: 75 JDX8 Tach
Does one of the wires have an in line glass fuse? The next question would be, do your lights work?
DE
DE
Dustin Elder
Salem, OH
Salem, OH
Re: 75 JDX8 Tach
Yea it has a fuse and the fuse isnt blown, I tested it with a volt meter. The headlight works also. I also need a cylinder for it on the stator side. I cant find both .040 over pistons for it. PM me if anyone has one. (I also put my wanted cylinder in the classified section.)
Re: 75 JDX8 Tach
Kieth,
I'm about 90% certain that these pistons are still avalible aftermarket. Matt, can you get them from PU or SPI?
DE
DE
Dustin Elder
Salem, OH
Salem, OH
Re: 75 JDX8 Tach
Dennis Kirk Part #: 13-589, left hand... 13-890, right handkdowning08 wrote:Yea it has a fuse and the fuse isnt blown, I tested it with a volt meter. The headlight works also. I also need a cylinder for it on the stator side. I cant find both .040 over pistons for it. PM me if anyone has one. (I also put my wanted cylinder in the classified section.)
Re: 75 JDX8 Tach
Sorry, I can't be of any help. It's most likely been discontinued for a while.
Re: 75 JDX8 Tach
These part #'s were from a 2009 DK catalog. The right hand piston is now obsolete. The left hand is still available.harleysportster wrote:Dennis Kirk Part #: 13-589, left hand... 13-590, right handkdowning08 wrote:Yea it has a fuse and the fuse isnt blown, I tested it with a volt meter. The headlight works also. I also need a cylinder for it on the stator side. I cant find both .040 over pistons for it. PM me if anyone has one. (I also put my wanted cylinder in the classified section.)
