Coolant Temperture for a '78 440 Liquifire
You guys running a '78 Liquifire, what seems to be the normal coolant temperture once it is warmed up. I have a numbered gauge reading about 180 running around the field with marginal snow conditions. 180 in these gauges is near the top end of the green zone.
Re: Coolant Temperture for a '78 440 Liquifire
mine runs 1030 to noon whatever that is on the gauge
So what do you do after lunch Wade?
ba bump pump...
ba bump pump...
Like all farmers, takes a nap!
Harley, IF I remember right those are close to being 160-180 deg stats & also IF I remember right they did run real close to the top of the green, that's why I always used the Dator style gauges with the numbers so I knew right where it was...
Grumpy
Grumpy
Mine must have a thermostat stuck open or someone removed it altogether. It runs about 130 most of the time.
Brian Redick
1978 John Deere Liquifire 340
Thanks Kenny, I know more tomorrow in deeper snow. Our '76 Liquifire never ran much over 140 ish.ICCSF 108 wrote:Like all farmers, takes a nap!
Grumpy
I took it out for another ride today. The outdoor temp was around 28 degrees. The snow condition was 6-8 inches and loose. The coolant temp balanced out around 140, so it looks like all is good.
clearly i got my nap time confused with the time i usually roll out in the mornings , after further investigation im saying 9:00-10:30 about 140 or so wadeJDT wrote:So what do you do after lunch Wade?
ba bump pump...
