1982 Liquifire resurrection
Re: 1982 Liquifire resurrection
Nice!!!
Nice sled Paul! Youre making better progress than me...
Looks like youll be ready for the HOF ride...
How do you like that HSR ignition?
- Danzig
- Real Name: Paul File
Thanks Bill !!
Eric...I would not trade this for a 1980 ever !!.. One to two pulls and she purrs. I love it.
That's one nice sled you have there Paul
Nice work there Paul.
Hey Bob, you reading this????
- Real Name: Bob Amber
Yep! If you mean me?:?:
Bob A.
Sent from my DROIDX using Tapatalk 2
Bob A.
How did you put the crank seals in with only pulling the bottom case off?
- Danzig
step by step here ya go...
remove the black engine mount bracket, then remove the flywheel, then remove the stator and the black engine mount bracket with the flywheel housing due to the wiring for the stator goes through it, next remove water pump and hose leading to thermostat housing, next remove gear drive cover for the waterpump and oil pump, flip engine upside down remove all bolts holding the halves together, gently pry off the bottom half, next grab ahold of crank on both end and pull it towards you about and inch keeping pistons inside the cylinders, remove mag seal. PTO seal is in the gear case cover.
- Danzig
Danzig wrote:step by step here ya go...
remove the black engine mount bracket, then remove the flywheel, next remove water pump and hose leading to thermostat housing, next remove gear drive cover for the waterpump and oil pump, flip engine upside down remove all bolts holding the halves together, gently pry off the bottom half, next grab ahold of crank on both end and pull it towards you about and inch keeping pistons inside the cylinders, remove mag seal. PTO seal is in the gear case cover.
Paul,
Did you change the inner seal behind the oil pump gear?
- Danzig
yep...sure did
What trick did you use to get the gear off? Seems that may be tough with the crankcase in the way..?
- 69camaro
- Real Name: Duane Gjerseth
Hey Paul,
Nice work. The Jackson county Black River Falls area trails are open. You should come up and ride that baby in the land of cheese. It's snowing like crazy here right now.
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
- Danzig
Eric,
Plenty of room, just pull the entire crank out with the piston attached to it, but dont go to far with that you dont wana pull the piston out the bottom of the cylinders. Once you have the crank pulled back, lay the engine on its side so you wont fight the pistons falling back in, which isnt too likely to happen due to the compression, leave the spark plugs in.
