After riding around for a while, I came to the conclusion that RPM seemed a little on the low side. I changed the driven clutch spring to hole 3 but not sure of where it was. I think hole 2 which is factory. Sled seems better like more in the power range. Now I want to raise the drive engagement speed by 500 to 750 rpms. I have a rust colored spring(real rust) and it engages just under 4000 rpm.
this will be a 2 part msg as i have to make a phonecall that may time me out.....
clutch work.
clutch work.
Current:
77 John Deere Cyclone 440
98 Yamaha SRX700
Past:
1968 Rupp GT300
1970 Evenrude Bobcat 440
1976 Arctic Cat Cheetah 440
1976 Ski-Doo TN'T Everest 440
1978 Yamaha Exciter 440
1979? Yamaha Enticer 300
1979? Yamaha Enticer 250
1987 Polaris Sprint 340
98 Yamaha SRX700
Past:
1968 Rupp GT300
Re: clutch work.
Ok so I will look at comets website the find spring color I want and repost results..
Current:
98 Yamaha SRX700
Past:
1968 Rupp GT300
98 Yamaha SRX700
Past:
1968 Rupp GT300
Re: clutch work.
The stock "F " weights with a new silver spring would give you a clutch engagement of 3700 to 3900 rpm. If you knew someone with the spider removal tools, remove one of the spacers under the spider and that would increase the engagement just over 4,000 rpm.
Re: clutch work.
Fine Tune Manual
http://www.vintagesnow.com/John_Deere_f ... manual.pdf
