78 cyclone headlight problem
every time i hit my brake the headlight gets really dim anyone have any ideas?
Re: 78 cyclone headlight problem
Check / clean all the grounds to the lights.
In addition to what Harley said look very closely at the back side of the tailight assembly.
You may find that of the two wires that go into the small hole at the rear of the socket, the one for the brakelight filement may be touching the socket base if too much bare wire is showing beyond the insulation.
Another problem area may be under the seat. Again the brakelight wire may have had the insualtion rubbed off and it is touching the tunnel.
I have seen these two problems many times.
thanks i will check those areas...i did just put the seat on,i'll post what i find...dave
hi
Remove seat and check wiring I bet a mouse chewed the wires up and shorts when you hit the brakes.
Current:
77 John Deere Cyclone 440
98 Yamaha SRX700
Past:
1968 Rupp GT300
1970 Evenrude Bobcat 440
1976 Arctic Cat Cheetah 440
1976 Ski-Doo TN'T Everest 440
1978 Yamaha Exciter 440
1979? Yamaha Enticer 300
1979? Yamaha Enticer 250
1987 Polaris Sprint 340
98 Yamaha SRX700
Past:
1968 Rupp GT300
