78 cyclone track issue
i have another problem ,it is with the track on my 78 cyclone the track that is on it is from a 77 and the center drive lugs look to me to be rubbing on the top shock mount,the 78 does not have center drive lugs are these not interchangeable?
Re: 78 cyclone track issue
Yes, the 76 thru 78 tracks are interchangeable on the Cyclone / early Liquifire series. You could be seeing previous wear marks from when the track was on the 77. The top of the shock mount rubs the inside of the track until the suspension is crompresses slightly. Also, check the nylon wear strips that the track rides on. They could be worn down, causing the track to contact the shock mount.
I am using the same track in my 78 Cyclone.
thanks harley ,the slides look decent it does feel like it is upfront somewhere.i'm gonna have to do some more digging
i know this was awhile ago ..but your drive wheels and shaft are quite different
Correct, the original drive-shaft was round and the drivers were probably white. The hex drive-shaft was a later update along with the hex drivers.
thanks harley..one of my drivers is loose on the shaft and making a "clunky " sound at slow speeds gonna take it apart and see if i can mabye shim it ...have you ever ran into this problem?
Yes, I have seen the holes in the driveshaft egg-shaped.
do you know what drive shaft that is hexagon i could use ,there is a driveshaft on ebay with the drivers ...thanks dave
The hex shaft from a Trailfire/Sportfire/Liquifire will work but you will need to find 2.52 hex drivers to use on the Cyclone. I have seen the oem round shafts on ebay and the classifieds now and then.
- 69camaro
- Real Name: Duane Gjerseth
I have a nice shaft and drivers sitting on a shelf if you are interested.
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
thanks for the information harley and 69camaro really appreciate it
