PPG Paint Code
Contains tips for painting and codes that our members have used.
eddingsj
PPG Paint Code
Post by eddingsj »
Does anyone happen to have the PPG paint code for the Case B17567N that can be used on the Trailfires?
Jeff Eddings
South Weber, UT
1980 Trailfire 440
skoalmint
Re: PPG Paint Code
Post by skoalmint »
I have The dupont code,Dont know if that will help? It is their nasson lie of paint .Brock
eddingsj
Re: PPG Paint Code
Post by eddingsj »
Ok, so I bought some Case/IH silver/ardent paint from my local Case dealer because I couldn't cross reference the Case Paint to a PPG. However, my buddy at shop that is going to spray the frame and hood for me states that this paint will not accept a clear coat. So I am back to square one! I have some books from PPG that my buddy gave me to look through and I am going to try and match it to a sample I sprayed out of a can of Case/IH B17567N.
Has anyone sprayed their sled with a silver/ardent color from PPG that was a very close match to the original JD Winterfrost II that could provide me with the color/code they used.
Thanks in advance
Jeff Eddings
South Weber, UT
1980 Trailfire 440
skoalmint
Re: PPG Paint Code
Post by skoalmint »
Jeff ,The case IH paint is very close but is not exact.You must not have many paint stores in your area.I have the Dupont code that is 98.9% correct.Sorry i cant help w the PPG code. Brock
ihengineer76
Real Name: Tom Rehberg
Re: PPG Paint Code
Post by ihengineer76 »
I used Napa's Crossfire paint line and had good luck with it. The paint was Crossfire silver metallic. The code was 53-42159-00-B, but it is a single stage enamel, not base/clear. I had good luck and thought it matched fairly well. You could probably use the code and get it in base/clear if you want. The size of metal flake was a little smaller than factory, but the color was quite close. Here is a couple pictures of a sled I did with this paint. The tunnel and belly pan are original, and the hood is repainted to give you a comparison.
1975 340/S - I-500 raced sled
eddingsj
Re: PPG Paint Code
Post by eddingsj »
skoalmint wrote:Jeff ,The case IH paint is very close but is not exact.You must not have many paint stores in your area.I have the Dupont code that is 98.9% correct.Sorry i cant help w the PPG code. Brock
Brock,
Could I get that Dupont code from you and see if I can do something with it?
Thanks - jeff
Jeff Eddings
South Weber, UT
1980 Trailfire 440
skoalmint
Re: PPG Paint Code
Post by skoalmint »
Hello Jeff,Ok here is the Nason -ful-base B/C (dupont line) 384644 IF A. code 6895 metalic/ridescent content >5 grams/liter.It says it is a ford color on the can, so it must cross up very close to some ford product.Hope this helps,Good luck.Brock
eddingsj
Re: PPG Paint Code
Post by eddingsj »
skoalmint wrote:Hello Jeff,Ok here is the Nason -ful-base B/C (dupont line) 384644 IF A. code 6895 metalic/ridescent content >5 grams/liter.It says it is a ford color on the can, so it must cross up very close to some ford product.Hope this helps,Good luck.Brock
Brock,
I was able to take the information you provided me down to my local auto paint store and they sprayed out a card for me. It was perfect and is going to work just fine for my application.
Thnak you for providing me that information, it made my search for the correct color paint a lot easier.
One less thing to worry about on this rebuild!
Jeff
Jeff Eddings
South Weber, UT
1980 Trailfire 440
skoalmint
Re: PPG Paint Code
Post by skoalmint »
Anytime Jeff ,Glad i could help.I also have the Emerald green code as well if you ever need it.Brock
JD600
Re: PPG Paint Code
Post by JD600 »
I think we have Mean Green nailed down pretty tight too Brock.
DE
skoalmint
Re: PPG Paint Code
Post by skoalmint »
Sorry D forgot to mention that one!! Brock
JD600
Re: PPG Paint Code
Post by JD600 »
Thats ok, i get left out of a lot of people's thoughts lol
DE
skoalmint
Re: PPG Paint Code
Post by skoalmint »
At least when u call me I usually answer.LOL. U started it LOL. Brock
