1980 JD Liquifire by SnowKat79
snowkat79
Post by snowkat79 »
carb shots, and a few before shots.....
snowkat79
Re: 1980 JD Liquifire by SnowKat79
Post by snowkat79 »
a few more pics.....
snowkat79
Post by snowkat79 »
more pics.....
snowkat79
Post by snowkat79 »
too bad these didnt post in order like I wanted!
snowkat79
Post by snowkat79 »
Just got all parts sand blasted, I will post pics as soon as I get them painted.
Danzig
Real Name: Paul File
Post by Danzig »
where you located in Central Illinois ?
TASKY
Post by TASKY »
How do you like that fancy carb cleaning machine? Details please...
snowkat79
Post by snowkat79 »
Danzig wrote:where you located in Central Illinois ?
Elliott, Paul. I have talked to you on the phone before a few years ago.....cant rememebr why. I was under a different name on the forum then, kawtoy_77.
snowkat79
Post by snowkat79 »
TASKY wrote:How do you like that fancy carb cleaning machine? Details please...
I love it, now that I have found a good cleaning solution to put in it! I bought it at Harbor Freight, used the powder junk they have on the shelf as a cleaning solution. I was unimpressed at first. After mulling it over, I decided I would give another shot with a proper carb cleaning solution. What I could find online was around $60/gal. I refuse to pay that, considering its about what I paid for the unit itself!So, I thought about trying Simple Green in there. Its not flammable, not corrosive, and non-toxic. I bought a gallon of it at Big R for $7, and tried it at full strength on a junk carb I had lying around. I makes quite a stink, but works very well. I would not recommend it for use in your house, lol!I wish I had a bigger cleaner now, something I could put an assembled set of 4 motorcycle carbs in.
Danzig
Post by Danzig »
:beers;
snowkat79
Post by snowkat79 »
Can anyone tell me if these are the correct ski's for a 1980 Liquifire? My '81 has something completely different on it for ski's. Also, someone put longer bolts the shock eyes, and it now has 2 shocks per ski. (Which I know is not correct)
Your skis look like aftermarket skis made by Steffes. The 81+ skis are different than 80 skis. The 80's had a wide opening where the shock mounts
snowkat79
Post by snowkat79 »
Thanks Nick! I figured there was something fishy, when the wear bars wouldnt fit quite right.
I will get pics of the '81 ski's shocks, and other parts...appreciate the info.
snowkat79
Post by snowkat79 »
SO I have everything back together, except for one bolt on each ski.....(I will go shopping for that after work) Everything looks MUCH better. I used grade 8 hardware.
snowkat79
Post by snowkat79 »
Here is the conglomerated crap that is on my '81 LF.....
