Replacement hoses
hounds84lhs
Replacement hoses
Post by hounds84lhs »
Hi, rebuilding a 1980 Liquifire. Where can I buy all four hoses for the radiator and heat exhanger? I see New Breed has one, where can I get the other 3?
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
69camaro
Real Name: Duane Gjerseth
Re: Replacement hoses
Post by 69camaro »
They are usually in great shape so there has been no repops. If yours are pretty worn I'm sure I have some extras in nice shape.
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
Grumpy
Post by Grumpy »
Are these other hoses something we should be thinking about repopping also?? along with the older Liquifire hoses & Dators & Sprintfires also??
Grumpy
Do War Protesters have reunions? IF So, What do they talk about??
jdrob
Real Name: Rob
Post by jdrob »
Kenny; How about the 80's LF airbox hose? I know I have been asked at least 50 times if I have this part and My reply is always the same. "NO" and "I need 2 myself". Either style will work for me.. :usa:
Jdrob
Grumpy
Post by Grumpy »
jdrob, that could be a possibility, but I think that the airbox screens would also be a good repop???
Grumpy
jdrob
Real Name: Rob
Post by jdrob »
Kenny I totally Agree 100%. I believe the Sportfire and trailfire tubes Could be easily fabricated at home. At least the basic tube anyway. The Liquifire tube is going to take some finess b/c of the perforated tubing.
Also Kenny do you know if the seals you had re-popped for the earlier airboxes (dator,340/s ??) would they possible fit the tubes from the newer fire series airboxes? OR are they a completely different style. Maybe MATT can answer this question as well? :usa:
Jdrob
Grumpy
Post by Grumpy »
rob, I believe the part numbers are the same. This past winter Chris & I fabricated a couple of Dator air tubes from scratch, I think that they turned out to be as good looking as the Chinese ones I had repoped... If someone can send me one from a trailfire or sportfire I'll try them out when I get back north after Christmas.. I'll see IF I can find some flat perferated material like the Fire series Liquifires use also.
Grumpy
jdrob wrote: Also Kenny do you know if the seals you had re-popped for the earlier airboxes (dator,340/s ??) would they possible fit the tubes from the newer fire series airboxes? OR are they a completely different style. Maybe MATT can answer this question as well? :usa:
Yes, they fit all the fire series too.
