Replacement hoses
hounds84lhs
Replacement hoses
Hi, rebuilding a 1980 Liquifire. Where can I buy all four hoses for the radiator and heat exhanger? I see New Breed has one, where can I get the other 3?
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
- 69camaro
- Real Name: Duane Gjerseth
Re: Replacement hoses
They are usually in great shape so there has been no repops. If yours are pretty worn I'm sure I have some extras in nice shape.
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
Are these other hoses something we should be thinking about repopping also?? along with the older Liquifire hoses & Dators & Sprintfires also??
Grumpy
Grumpy
Do War Protesters have reunions? IF So, What do they talk about??
- jdrob
- Real Name: Rob
Kenny; How about the 80's LF airbox hose? I know I have been asked at least 50 times if I have this part and My reply is always the same. "NO" and "I need 2 myself". Either style will work for me..Are these other hoses something we should be thinking about repopping also?? along with the older Liquifire hoses & Dators & Sprintfires also??
Jdrob
jdrob, that could be a possibility, but I think that the airbox screens would also be a good repop???
Grumpy
Grumpy
- jdrob
- Real Name: Rob
Kenny I totally Agree 100%. I believe the Sportfire and trailfire tubes Could be easily fabricated at home. At least the basic tube anyway. The Liquifire tube is going to take some finess b/c of the perforated tubing.jdrob, that could be a possibility, but I think that the airbox screens would also be a good repop???
Also Kenny do you know if the seals you had re-popped for the earlier airboxes (dator,340/s ??) would they possible fit the tubes from the newer fire series airboxes? OR are they a completely different style. Maybe MATT can answer this question as well?
Jdrob
rob, I believe the part numbers are the same. This past winter Chris & I fabricated a couple of Dator air tubes from scratch, I think that they turned out to be as good looking as the Chinese ones I had repoped... If someone can send me one from a trailfire or sportfire I'll try them out when I get back north after Christmas.. I'll see IF I can find some flat perferated material like the Fire series Liquifires use also.
Grumpy
Grumpy
Yes, they fit all the fire series too.jdrob wrote: Also Kenny do you know if the seals you had re-popped for the earlier airboxes (dator,340/s ??) would they possible fit the tubes from the newer fire series airboxes? OR are they a completely different style. Maybe MATT can answer this question as well?
